Torque on wheel nuts
PAPET
  • 2014 DODGE CARAVAN
  • 3.6L
  • V6
  • FWD
  • 40,000 MILES
I just want to ask how many pounds of torque on the wheel lug nuts of my vehicle? Thanks and hoping for your most appreciated reply.
Thursday, November 24th, 2016 AT 10:00 AM
WRENCHTECH
  • 20,757 POSTS
The lug nuts to a final torque of 135 Nm (100 ft. lbs.) here is a video to show you how to tighten the lugs using a torque wrench
https://youtu.be/_HIaE1MyDiw
Thursday, November 24th, 2016 AT 1:52 PM
PAPET
  • 102 POSTS
  • 3.6L
  • 6 CYL
  • FWD
  • 40,000 MILES
I just installed my winter tire with steel rims today. But my problem is, it is making a noise when I slow down and I even put on a new lug nuts. With the aluminum rims on, this noise can not be heard but. The nuts are tight enough but it is still it is making this noise clanging noise. What must be the problem? Hoping for your most appreciated reply. Thanks.
Tuesday, March 12th, 2019 AT 8:55 PM (Merged)
HMAC300
  • 48,601 POSTS
Try different lug nuts the old nuts may be bottoming out on stud and not seating in wheel.
PAPET
  • 102 POSTS
As I said earlier that I just installed a brand new lug nuts. So you mean I have to put a new one? Thanks
HMAC300
  • 48,601 POSTS
I did not see the new nut part. Jack up one of the wheels and see if it is loose on the hub if not then it may be just the thing with the wheel. If wheel is loose you can get spacers to take the slack up 1/8" would do it.
PAPET
  • 102 POSTS
There is no movement at all. And what do you mean "it might just the thing in wheel? Is it dangerous to drive with that kind of noise? Thanks once again.
HMAC300
  • 48,601 POSTS
Do the new wheels have hub caps? If so then take them off and see if you still have the noise. I do not think it is dangerous to drive just irritating. You can always take to a local mechanic and see what he says. A lot of hub caps make weird noises a lot of times to or check for rocks caught in the wheel as normally I cannot think of anything that would cause what you are talking about with new wheels.
2CP-ARCHIVES
  • 4,542 POSTS
  • 2005 DODGE CARAVAN
  • 130,000 MILES
Had new ti how do I remove themres put on thay rounded off two lug nuts
  • 52,797 POSTS
They make special sockets to remove the nuts or else you need to drill out the stude and drive it out of the nut
BONOCCHIO
Tires and Wheels problem
2005 Dodge Caravan 6 cyl Front Wheel Drive Automatic
2 rear wheel lugs broken off. How do you replace the lugs, as it seems that the rear bearing cover will not allow you to remove the hub holding the studs?
  • 108,269 POSTS
You need to punch out the old ones and replace them. You don't need to remove the hub.
