1998 Volvo S70 Code says the coolant temp. is low
1998 VOLVO S70
14,400 MILES • 6 CYL • 2WD • MANUAL
DAN FICHTE
I had cylinder head rebuilt after timing belt broke. I assembled the engine myself. Engine now runs fine, but check engine light stays on and radiator fan always runs after engine is shut off (maybe while engine is running, too, but I can't hear it). I had code read and it says coolant temp. is low. Non-volvo mechanic suggested replacing thermostat. If it is thermostst, would this cause the radiator fan to run after engine is shut off when it never did before repairs? Any suggestions?
Sep 18, 2008 at 5:45 PM
