Check engine light and coughing and sputter
SILVEROZEE
  • 1999 TOYOTA RAV4
  • 4 CYL
  • MANUAL
  • 21,000 MILES
Engine was replaced a couple years ago with a Japanese job. It has had an intermittent cough for a few weeks which I thought may be due to bad gas so I switched stations and it seemed ok for a few days but now the cough is worse and to day the check engine light came on and car runs very sluggish and back fires a bit. Check engine light does not stay on but for a few minutes then either goes out or starts blinking.
Monday, August 3rd, 2009 AT 4:17 PM
  • 31,937 POSTS
Hi there,
There is a code stored in the ECU memory this will be an indication as to your problem, get a scan and report the code here for more assistance. Some auto parts stores will scan for free, call a few and find out.
Mark (mhpautos)
Check out the guide below on check engine lights and common causes
https://www.2carpros.com/articles/check-engine-light-top-ten-reasons
Monday, August 3rd, 2009 AT 5:19 PM
KIDCARDIO
  • 1999 TOYOTA RAV4
  • 4 CYL
  • MANUAL
  • 193,000 MILES
My engine check light code is p1130, what should I check first?
Thursday, January 2nd, 2020 AT 8:50 PM (Merged)
DTC P1130 BANK ONE, SENSOR ONE, AIR FUEL RATIO SENSOR" might want to inspect the wiring if okay replace the sensor and see what happens
Its located on left side of engine in center of engine compartment in exhaust -sorry no pic for exact location
KACORT
  • 1998 TOYOTA RAV4
  • 4 CYL
  • 4WD
  • 128,500 MILES
Hello Car People -
My check engine light came on about 6 months ago and went out after I bought gas. It came on again a month ago and when I removed and retightened the gas cap, it went out. Sadly, it came on again and this did not "fix" it. The light did go out on a short highway drive but came back on when I restarted the car. The mechanic says an EGR code came up and that they could chase that problem and still not find it but that it could be the EGR valve. Could you please share your expertise?
Thanks much -
Katie
BMRFIXIT
  • 19,053 POSTS
Most common is the EGR valve vacuum solenoid
also check and clean the EGR valve
