1992 Toyota Pickup KEEPS BLOWING efi fuse and fuse link
1992 TOYOTA PICKUP
255,436 MILES • 4 CYL • 4WD • MANUAL
FATS
when first quit blew the 15amp efi fuse in fuse box under hood replaced fuse ran for ashort time then blew am2 30amp fuselink checked all wireing for shorts could not find any local mech. said fuel pump was shorting out put new fuel pump and screen in ran ashort time blew fuse again can replace fuse will set and idle for hours runs fine if you drive can go about 2-3miles and blows fuse or fuselink any help would be very gratefull for. thankyou.
Feb 4, 2008 at 1:02 PM
TOYOTADOG
[quote:5aca1d79af="fats"]Electrical problem
1992 Toyota Pickup 4 cyl Four Wheel Drive Manual 255436 miles
when first quit blew the 15amp efi fuse in fuse box under hood replaced fuse ran for ashort time then blew am2 30amp fuselink checked all wireing for shorts could not find any local mech. said fuel pump was shorting out put new fuel pump and screen in ran ashort time blew fuse again can replace fuse will set and idle for hours runs fine if you drive can go about 2-3miles and blows fuse or fuselink any help would be very gratefull for. thankyou.[/quote:5aca1d79af] you might try un hooking your horn fuse b/c i had a simular problem and that helped but try a bigger fuse than u would usually use
Feb 10, 2008 at 9:54 PM
