1994 Toyota Corolla Renewing the front crankshaft oil seal
1994 TOYOTA COROLLA
MDORIA
Engine Mechanical problem
1994 Toyota Corolla 4 cyl Two Wheel Drive Manual
Having trouble removing the crankshaft sprocket from the crankshaft. If fells like glued in! Any suggestions?
Feb 7, 2010 at 6:48 AM
MMPRINCE4000
  • CAR REPAIR CONTRIBUTOR
  • 8,548 POSTS
Sprocket slides on and off. Try some PB Blaster on it and tap with a rubber mallet.
Worst case, use a small prybar and remove, you will probably break the old one, so make sure you can get one from Toyota before you start.
Had the same problem with a 91 Corolla. Had to pry it off and put a new one on.
Feb 7, 2010 at 7:23 AM
MDORIA
Had to break it off. Thank you very much. The replacement part was cheap.
Feb 11, 2010 at 7:39 AM
MMPRINCE4000
  • 8,548 POSTS
Glad to hear it, sometimes they can be a pain, I've had to break a few off in my time also :) .
Feb 12, 2010 at 7:36 AM
