2005 Toyota Camry ABS Light and Traction Control System Lig
ZAPPER232
  • 2005 TOYOTA CAMRY
  • 6 CYL
  • FWD
  • 145,000 MILES
I had a check engine light on and used my code reader to read the code and reset the light. Sometime during that process, the ABS and Traction Control lights came on. My reader will not clear ABS lights so I disconnected the battery. That shut the lights off and that worked for a short while, but then the lights when back on after a few blocks of driving. I know the typical causes for these lights to go on, but it seems unlikely that a mechanical failure would coincide so closely to my activities with resetting the check engine light. Thoughts as to the cause?
Do you
have the same problem?
Wednesday, November 4th, 2009 AT 11:21 AM
STEVEW84
Find out what the code is then repost.
Thursday, November 5th, 2009 AT 9:29 PM
Recommended Guides
