1996 Toyota Camry Engine leaks oil
TOYOTAOWNER-96
  • 1996 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 125,000 MILES
I have brought the car to numerous mechanics
to find the oil leak, to no avail.
I noticed recently that the dogbone engine mount
bushings were worn.
Could movement as of a result of worn bushings
cause the engine to leak oil?
Sunday, November 23rd, 2008 AT 2:48 PM
LEGITIMATE007
  • 5,121 POSTS
I f these ""mechanics"" cant find this oil leak, one of them should of atleast suggested putting tracer die of somsort into the oil so that you can see where its comming form. Approximately what area does it look like its comming from?
Sunday, November 23rd, 2008 AT 3:03 PM
BMRFIXIT
  • 19,053 POSTS
10x 4 the PM
Very possible and common if the oil leak coming from the front its the oil pump seal and gasket
and if so have replaced with the timing belt
good luck
Sunday, November 23rd, 2008 AT 6:07 PM
