1994 Toyota Camry What to expect
1994 TOYOTA CAMRY
14,300 MILES • 4 CYL • 2WD • AUTOMATIC
PROJOCS
I am so glad I found this site! What a resource, Thank you all!
My question is: I bought my Camry sight unseen (not a smart move) I am faced with a bunch of issues and I need to know how much I can expect to pay for these repairs so I can budget accordingly.
My rear shocks (or struts?) are shot! My alignment pulls so hard to the left I fill like a NASCAR driver ! How much will each repair run me(approximately)! Thanks.
PS. it leaks oil like a sieve.
Feb 20, 2008 at 9:26 PM
BMRFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 19,053 POSTS
Where is it leaking oil from
is it from the front by the timing cover if so then check the oil pump gasket
also check oil pressure switch
check your tires
make sure they are the same size and enough air
good luck
Feb 20, 2008 at 10:01 PM
