1992 Toyota Camry Need Help
DABLAZEISON4EVA
  • 1992 TOYOTA CAMRY
Brakes problem
1992 Toyota Camry 6 cyl Front Wheel Drive Automatic
I put a new brake line for the rear on the car then a new hose for the front calliper, bled the brakes and everything. For some reason the brakes still dont work. Theres new rotors and pads in the front on both sides and the rear rotors and pads are still good. Do you have any suggestions?
Do you
have the same problem?
Sunday, October 5th, 2008 AT 6:26 PM
KENT PALMER
MAY NEED MASTER CYLNDER
Friday, October 10th, 2008 AT 10:17 AM
Recommended Guides
