I have a belt not a chain all images you shown are off a chain YouTube links are a chain which is different from mine. No visible marks anywhere on my belt or around near the cog. There is marks on the cogs for timing belt but no marks as to where it to be lined up.
Tuesday, October 27th, 2020 AT 8:03 AM
MECHANIC
Can you give me the complete VIN number so I can get the correct information?
Tuesday, October 27th, 2020 AT 8:51 AM
TONY PAZ
MEMBER
1 POST
2007 HYUNDAI SONATA
3.3L
6 CYL
2WD
AUTOMATIC
264,000 MILES
Periodic maintenance. Can you give me the timing belt size and routing?
Tuesday, October 27th, 2020 AT 4:03 PM
(Merged)
HMAC300
MECHANIC
This has a timing chain not a belt are you sure you just do not want the fan belt? Picture shows belt diagram. No size is given. Also, tension-er should be replaced. If you want timing chain install then it is too much for us to copy and paste you can rent the manual for a week for your car here on site.
Image (Click to make bigger)
(Merged)
RENEE L
ADMIN
Hello Tony,
If are interested in changing the timing chain yourself here is a link to locate a repair manual for your vehicle.
