Ignition switch replacement
JOE1953
  • 1999 BUICK LESABRE
  • 73,000 MILES
I am trying to get to the ignition switch so that I can check the wiring from ignition switch to connector I check for continuity between specified terminals with ignition switch in specified position, I didn't get no continuity between D5(RED)and D6(PINK)WIRE Didn't see anything on 1999 buick lesabre how to remove steering column trim panel can you send me more information.
Tuesday, September 25th, 2012 AT 12:20 AM
CAROLINACARCONNECTION
  • 66 POSTS
From what I remember you pop the airbag out. With a flat screw driver go into the back of the steering wheel you will see 2 slots insert ur screwdriver into the back and turn 1 quarter turn. You will feel it click. Repeat on the other side. Remove steering wheel then remove the multi function switch then the cover will side off the column.
Tuesday, September 25th, 2012 AT 5:32 AM
JOE1953
  • 619 POSTS
I am trying to get to the ignition switch I need to lower the steering column the ignition switch is located on the steering column, but there is a panel under the steering column I need to remove so that I can lower the steering column I need to know where the bolts is located on the panel.
Tuesday, September 25th, 2012 AT 6:02 AM
  • 66 POSTS
The wood panel in the center of the dash pops off any there are screws umder it and some 7 mm on the bottom. Sorry I do not have anyway to access pics of the screw location. If there isnt wood it will be the panel with lesabre wore on it. From what I remember u have yo remove the lower panel as one piece driver and pass side, On a 99 it should have the switch located in the top of the column right behind the steering wheel there should be no reason to lower the column
Tuesday, September 25th, 2012 AT 6:56 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,081 POSTS
I found more diagrams that make a little more sense. Check these out (below) Please let us know if you need anything else to get the problem fixed.
Monday, February 12th, 2018 AT 2:13 PM
DJBOND007
  • 3.8L
  • 6 CYL
  • 173 MILES
Can u send a video or diagram on how to remove a steering column on a 1999 buick lesabre
Saturday, August 3rd, 2019 AT 9:59 AM (Merged)
CARADIODOC
  • 33,755 POSTS
You need a copy of the manufacturer's service manual. That will have pages of instructions with line drawings, torque specs, and warnings related to air bags and steering linkages. You can also buy a subscription for just your model from AllData or Mitchell-On-Demand. Those are the sites repair shops use.
HMAC300
  • 48,601 POSTS
We have no videos on that see pics for removal.
JOE1953
  • 619 POSTS
  • 73,000 MILES
I don't see any screws in the panel where or they located.
RACEFAN966
  • 5,029 POSTS
Can you include a pic of what part of the panel you are refering to? Thanks it will help alot to answer your question.
JOE1953
  • 619 POSTS
The panel just below the instrument panel cluster I don't no how to send a picture.
RACEFAN966
  • 5,029 POSTS
If there are no screws from on the underside then it should pull off but I don't want to say that without seeing it. Pm me and I will give you email address so you send a pic there.
