Not cranking over
SMHILES73
  • 2007 SATURN OUTLOOK
  • 3.6L
  • 6 CYL
  • AWD
  • 110,000 MILES
My 2007 saturn outlook wont start or even crank. My wife started it this morning with the remote start but it shut off after 10 min. Now when I turn the key it does nothing, not even a click, but the rest of the electricals work exactly how they are supposed to. Replaced starter relay, load tested batt, soft reset computer.
Wednesday, January 7th, 2015 AT 3:08 PM
HMAC300
  • 48,601 POSTS
It sounds like you have a positive battery cable that is shorting out and dropping the connection which will stall the engine. Please check out the cable here is a guide to help you see what you are in for when doing the job. Use a test light to confirm the connection issue.
Check out the diagrams (Below)
Cheers
Wednesday, January 7th, 2015 AT 3:20 PM
1HEREIGNS1
  • 2008 SATURN OUTLOOK
  • 3.4L
  • V6
  • FWD
  • 138,000 MILES
Yep I had the same problem and the battery cable is what they replaced now everything works great. Cost me 230.00 bucks though.
Monday, March 19th, 2018 AT 2:59 PM (Merged)
SATURNTECH9
  • 30,869 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Cheers
