Engine Performance problem 4 cyl Front Wheel Drive Manual 45000 miles
My skoda octavia 1.9 TDI drives fine start on half a turne of the key when cold but dose not want to start when hot?
Thursday, February 18th, 2010 AT 3:42 PM
DAVE H
MECHANIC
Check/replace the crankshaft position sensor
SPONSORED LINKS
Sunday, February 28th, 2010 AT 8:43 AM
JUIME
MEMBER
2004 SKODA OCTAVIA
1.9L
4 CYL
TURBO
4WD
MANUAL
90,000 MILES
What happens is that when I try to ignite the car, the engine cranks but never start. I really don't know what to do with it. I checked the timing belt, the sparks, the fuses I mean all the usual things, but the engine never starts. I really wish you could help me
regards,
Juimy
Friday, December 15th, 2017 AT 5:01 PM
(Merged)
MECHANIC
Is the engine getting a good hot blue spark to the plugs? Is the fuel pump pressure within the manufacturer's specs?
(Merged)
JUIME
MEMBER
I checked the fuel pump, the gas gushed in the cylender when I try to unscrew it just a bit, but there is a strange white smoke coming underneath the engine. I forgot to tell you just before the engine stops running, it was out of oil because I have a leaking in the oil tank.
Friday, December 15th, 2017 AT 5:02 PM
(Merged)
MECHANIC
The smoke comes from under the engine? Also, if you have fuel and spark to the engine, it should start. Tell me this. If you use starting fluid, will the engine start for a couple seconds?
SPONSORED LINKS
(Merged)
JUIME
MEMBER
Yes the smoke comes from under the engine. What do you mean by Starting fluid? Is it that kind of spray, you spray in the pipe that goes to the air filter? If I tried this, the engine sounded like it was starting but did not actually.
Juimy
(Merged)
AARONMAYNARD
MEMBER
2000 SKODA OCTAVIA
2.0L
4 CYL
2WD
AUTOMATIC
125,600 MILES
Went out in car came back parked up went back out to car about 20 mins later car won't start and has rotten egg smell coming in the cab of the car drained battery so charged battery over night tried again in the morning still the same not starting and has egg smell battery seems to be struggling to turn over engine checked fuel to injectors all working properly any help thanks
(Merged)
MECHANIC
You need to spray it into the throttle body.
(Merged)
MECHANIC
A rotten egg smell is usually from the catalytic converter. Have you checked to see if the fuel pressure is within the manufacturer's specs? Are you getting spark to the plugs? Is there a chance the timing belt has broken or jumped timing?
(Merged)
JUIME
MEMBER
Thank you for the hint, I will try to. But what do you think the problem may be? Is there any possibility for the problem to have any link whasoever with the timing chain? Which would mean an engine problem, right? Is the turbo play any role in the engine ignition power?
(Merged)
AARONMAYNARD
MEMBER
All fuel and spark plugs are fine it fired when it was warm last night but run very lumpy and cut out and now I have the smell and no firering
(Merged)
MECHANIC
If the timing belt has broken or skipped time, it won't start. No to the turbo causing this issue. Let me know what happens with the starting fluid and that will help me at least diagnose where the problem is coming from. If you don't want to use the starting fluid, you can check for spark to the plugs and check to see if the fuel pressure is within the manufacturer's specs.
SPONSORED LINKS
(Merged)
MECHANIC
If you have spark and fuel to the engine, it should run. The smell has me a bit confused. Have you tried disconnecting the catalytic converter to see if it will run then?
(Merged)
AARONMAYNARD
MEMBER
I found the smell its the battery because its nacured winding it over to much has killed it put new battery on it now it works thanks for help
(Merged)
LISAMARIE000
MEMBER
2000 SKODA OCTAVIA
2000 Skoda Octavia 4 cyl Front Wheel Drive Manual
It starts then you press on the excelerator the car konks out
(Merged)
MARMITE
MEMBER
I had a rover that did that and it was the rotor arm
a guy at work has a l reg skoda favorit and his did the same
it was his rotor arm as well
thats if they still use rotor arms in your car. Worth a shot
(Merged)
MECHANIC
Glad you got it fixed!
(Merged)
RAJESH19
MEMBER
2002 SKODA OCTAVIA
2.0L
4 CYL
MANUAL
104,000 MILES
Engine is starting, again it is turning off, I have replaced crank sensor, checked fuses but no use,
mechanic is saying it is 'instrument cluster' problem is it real? Engine starting problem is related to cluser? Please help this issue.
(Merged)
MECHANIC
The cluster is an interesting idea, but I doubt it. Have you checked fuel pump pressure?
(Merged)
RAJESH19
MEMBER
Hi, ya I have checked fuel pump pressure its fine. Still same problem
