where is the Shift Control Solenoid located and how do i replace them
Nov 22, 2010 at 11:00 AM
DOCFIXIT
✓Experienced Mechanic
There is an "A"and "B" located inside trans on valve body. Drop pan remove hold bolt
Nov 22, 2010 at 11:02 AM
Automatic Transmission Shift Interlock (BTSI) Control Solenoid located in Center console.
Nov 22, 2010 at 11:05 AM
LUMINA HELP
MEMBER
1 POST
Where is the shift solenoid?
Jan 18, 2021 at 2:20 AM
(Merged)
Good morning,
The shift solenoids are on the valve body on the side of the transmission. Which one are you looking for and what is the issue? Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
