2005 Saturn Relay how do i change the transmission fluid pr
2005 SATURN RELAY
68,000 MILES • 6 CYL • FWD • AUTOMATIC
DEEPSEA334
MEMBER
FOLLOW
do i need to change the filter also? do i need to go to a service center to get it done properly?
May 24, 2010 at 11:50 AM
Repair Safety Notice:
This information is for general instructional purposes only. Vehicle repair can be dangerous.
Verify all information, follow manufacturer service procedures, use proper tools and safety equipment,
and consult a qualified repair shop when needed.
BLUELIGHTNIN6
AUTOMOTIVE REPAIR CONTRIBUTOR
at early miles like this it would be best to have the transmission fluid and cooler lines flushed at a shop instead of simple drain and refill. the filter should be replaced as well
