2001 Saturn L300 I/p telltale & mil lights
2001 SATURN L300
134,000 MILES • 6 CYL • 2WD • AUTOMATIC
F15ACTACE
  • 14 POSTS
ABS,SRS, & service(wrench) are on. No DTC's stored or pending. Reset service light, come right back on. No drivability problems or obvious malfunctions (except 1 will explain) ABS seems to be performing properly, can not get brakes to lock up. SRS light performs 7 flash check in when ignition is turned on, then stay's on. SRS system has never been deployed. Nothing appears to have ever been tampered with. Fuses & circuts are all ok. Gauges all work. Only 2 clues I have so far, 1. While driving with A/C on the blower will suddenly cut out for about 5-7 seconds then come back on. 2. speakers in rear doors do not work. I have been a mechanic for 20 years & I am very familuar with the OBD2 comp systems. Have investigated every possible cause from power dist. to ground distribution. The only thing left I cant do on my own is hook up a tech 2 scan tool or equal, oh reminds me EVAP I/M will not complete its drive cycle test, keeps coming up incomplete. Some how i just dont think its related but could be. BCM? PCM? TCM? I would think there would be a DTC or drivability issue accompany it if it was.
Sep 19, 2009 at 9:58 AM
MATHIASO
  • CAR REPAIR CONTRIBUTOR
  • 1,209 POSTS
Is this a CAN system?
Sep 19, 2009 at 5:33 PM
F15ACTACE
  • 14 POSTS
yes I believe it is ....emissions is CALIFORNIA. does list it as CAN . here is the vin if it helps
1g8jw54r21y577991
Sep 19, 2009 at 9:57 PM
MATHIASO
  • 1,209 POSTS
To diagnose a malfunction in the CAN system, a scan tool that can read " U" ( network) is required.
you allready have checkedthe circuit for short,and open,and check the ground and base voltage using a DMM, that is good but
if another module in the nettwork is disconnected and the module that set the DTC begins communicating, the problem is with the other moduleif all wirring connections are good and there is no change after unplugging each of the other modules(ECM,TCM,BCM,ABS) the module in question is likely at fault
Sep 19, 2009 at 10:44 PM
F15ACTACE
  • 14 POSTS
You saying "and the module that set the DTC begins communicating" in your responce has me wondering if you noted that in my orriginal post I stated there are No DTC's . I have an Actron cp9180 which includes controller area network. please read all my original post to avoid redundant info. Scan tool shows no codes & no pending codes, yet these lights persist ( SRS, ABS, & SERVICE w/wrench) Here are some samples of yesterdays circut testing and checking
https://images.2carpros.com/forum/automotive_pictures/411145_DSCF0227_1.jpg
Everything has been re assembled
Sep 20, 2009 at 2:50 PM
F15ACTACE
  • 14 POSTS
[quote:24b1904c04="mathiaso"]To diagnose a malfunction in the CAN system, a scan tool that can read " U" ( network) is required.
if another module in the nettwork is disconnected and the module that set the DTC begins communicating, the problem is with the other moduleif all wirring connections are good and there is no change after unplugging each of the other modules(ECM,TCM,BCM,ABS) the module in question is likely at fault[/quote:24b1904c04]
when implying a result of "no change after unplugging...." are you suggesting I unplug modules and power up the system & or plug & unplug with power hooked up? And which module is in question? The service light (BCM) will come on just because one of the other MIL lights is on. Whats also crazy is the scanner says all mils are off when they are not.
Sep 20, 2009 at 3:08 PM
MATHIASO
  • 1,209 POSTS
I checked it out, it is not CAN system on yhis car, the can system are on vehicle made from 2003, this one is 2001.
Find out if the vehicle have been wrecked berfore.
this is not only one problem, this is defferent problem.
you will need to work on each system diagram separatly.
I will be searching what harness all of them have in common.
I will let you know as soon I find something. if you do, let me know too.
talk to you soon.
Sep 20, 2009 at 5:57 PM
F15ACTACE
  • 14 POSTS
I do in fact have a lot more information, I just needed to get us on the same page & headed in the same direction. I appologize for the mix up about 'CAN' .
Now as for the history of the vehicle- No it most certainly has not been in a wreck. There has been 2 previous owners, ( mother -daughter) It has had a brand new transmission installed & from what I have found out, that seems to be the last major repair it recieved before being dormant for a while.(carfax)
I understand the requirements for re-calibration of TCM after transaxle replacement and it all seems to have bben done .
Now this is where it gets good.I bought the vehicle with smoke pouring out of the exhaust , barely running, & code 300 (or maybe 303) #3 mis fire detected. In a nut shell, had somehow put too much oil in it and thought the motor was no good. A total of 8.5 qrts to be exact. After an oil change , tune up, and replacement of the rear bank coilpack (front had already been recently done) plus a complete tear down of the intake ,plentom, air cleaner hosing , pcv sys, to remove engine oil, the engine has ran outstanding. No codes or SES light. This was well over 600 miles ago.
I am sure you will wonder how well of a job I did or didn't do. I will say this, I do it right or I won't do it at all. When it comes to Diag. I get obsessive.
The SRS module I have sent out to have the software re-installed & reset, with fingers crossed. Its only $49.
Its the BCM that has become the main focus, see if you can find out if it is normal to have mil's lit up without the presence of any DTC's. even if I don't get to the bottom it, you will be compencated, i am going to go put money on my card now.
Sep 20, 2009 at 8:59 PM
MATHIASO
  • 1,209 POSTS
You allready donated so , it is o k. I wiill follow you all the way untill we fix it. sorry for writting late because of my 12 hours work a day. I found something interesting. let start from the begining: ABS,SRS, & service(wrench) are on. No DTC's stored or pending. SRS never been deploy,ABS seem to be performing properly.there is no code for the service light. here is my point: the problem may be in the BCM . I'm sending the body system schematic the vehicle, and the data link connector that include the PCM. let 's cross finger. if the light for the SRS come back after the new SRS intallation,the BCM maybe bad. bu we must go through all the wirring from and to the BCM. I'm sending the diagram so you can look at it while we are waitting for the SRS. if you need any diagram let me know.
https://images.2carpros.com/forum/automotive_pictures/46384_pic1_2.jpg
save picture as. and zoom to see. The A/C on the blower that l suddenly cut out for about 5-7 seconds then come back on. 2. speakers in rear doors that does not work are separate issues that we can deal later. talk to you soon.
Sep 21, 2009 at 5:20 PM
F15ACTACE
  • 14 POSTS
Yes, yes, & yes. No worries about how long it takes to reply, as long as you keep replying. My friends call me DR. Phil cause I got lots of patience. I am totaly on the same page & have already conducted the wiring harness tests for the BCM. I have aquired all the wiring diagrams for the car but I'm not sure if I have that particular one, I will check at the garage tonight cause the writing isn't readable & gets worse when magnified. In the event that I don't have that diagram, I will be going over the harness again using that one as the referance for distribution. I too, dreadfully suspect the BCM, but want to be absollute before replacing it. Aside from the lights, it seems to perform its functions without any isssue's. Replacing one just because it can't turn the telltales out, its a joke but not funny. Your conclusions so far tell me I have been headed in the right direction. I will add the findings & results of the wiring review tonight.
https://images.2carpros.com/forum/automotive_pictures/411145_BCMnumbers_1.jpg
Sep 21, 2009 at 9:29 PM
F15ACTACE
  • 14 POSTS
Wet, wet, wet. I found evidence that the BCM has gotten wet at some point in time.
I was unable to enlarge the diagram without distorting the text, When the image is shrunk the pixels for the writing get screwed up. See if you can send it a little larger because i do want it for referance to continue testing.
It dawned on me today that theoreticly I could check all the leads coming out of the BCM that are supposed have (& correct me if I am wrong) a .5 volt to find a possible confirmation of the problem. What do you think? I believe I have the nessecary diagram to get that done.
Even though the SRS brain is out of the vehicle the light still flashes 7 times. That doesn't make sense to me, does it to you? I thought the flashing was a form of communication from the SRS that it was functional. Now this is obviously from the BCM, does this constitue BCM failure?
Sep 22, 2009 at 9:45 PM
MATHIASO
  • 1,209 POSTS
Before condamning the BCM, we should check the connection
( wire) between the BCM and the PCM.
if the BCM is or was wet , that mean moisture have got inside somewhere making damage .
the SRS light blink same as before, event the brain is not there,that tell me that the BCM is not communicating even it has power and ground.
that is my point of view.
let me know you install the new SRS.
Sep 23, 2009 at 6:03 PM
F15ACTACE
  • 14 POSTS
OK will do.
Moisture is from windshield, am having it replaced.
still waiting on SRS brain, will notify As soon as it arrives, will not be doing anything else until wiring checks are complete
Sep 30, 2009 at 10:59 PM
MATHIASO
  • 1,209 POSTS
thanks, and keep me update.
Oct 1, 2009 at 2:46 PM
F15ACTACE
  • 14 POSTS
SRS came back with "internal failure " written on it.
I am at a loss for what to take care of first. Gimmie your best suggestion, thanks phil
Oct 3, 2009 at 12:48 AM
MATHIASO
  • 1,209 POSTS
it is about cost, and allready spend lot of money in part, that does not include your time .
go all the way, if there is internal faillure as you said have it replace.one thing at the time .That is my point of view.
you are the boss,what do you think?
Oct 4, 2009 at 5:58 AM
F15ACTACE
  • 14 POSTS
When it comes to calculating my costs, I should tell you I work for myself. I look for vehicles in this condition & purchase them, repair them & sell them. I only like doing things one way, the right way. My funds aren't unlimited so Of course I want to avoid replacing anything that doesn't need to be replaced.
But what ever it takes to get it done right is what I will do, and my labor is my most abundant asset.
Now, the more i think about the SRS module, the more I wonder how 'they' (it was myairbag.com) where able to determine 'internal failure', especialy since the airbags have never been deployed & the vehicle never wrecked. Although I need to make sure the SRS system is fully functional before I sell the vehicle, my main concern for now is the mil lights, & main goal over all is for the vehicle to be without any mechanical needs period.
Lets focus on the BCM & ECM, I want to be certain that they need to be replaced, before replacing them (which will also mean reprogramming them) & that there is nothing existing that will cause the replacements to fail.
Even with the combination of information from Alldata, repairpath, & chilton, I am still unsure about which module is responsible for illuminating the mil lights or how to be certain if a specific module is bad.
I actually infact have not spent alot of money in parts. the ign coil pack is been the most so far.
I was left confused with your last set of instruct. about "we should check the connection
( wire) between the BCM and the PCM." According to the diagram I have for the PCM, there are 2 wires that are responsable for this. They are Tan & Tan w/white they are labled BCM CAN HI & BCM CAN LOW. Other than verifying that there is no loss in conection from one plug to the other (which I have & they are good) is there any way to check the signal going between them? IF ANYTHING most of all thats i need to know from you for now.
Also the diagram you sent covers everything for the auto-doorlock system which checks out just fine.
I do have a brand new developement with the vehicle. It died the other day right about the time it reached operating temp (185). For the first time ever I got some DTC's out of it when it happened. Of course if you let it cool, starts back up. Sounds like PCM has failed & as soon as it leaves limp mode, it dies. The codes stored were p0727 engine speed sensor signal, 1810 trans fluid pressure position switch, & p0443 evap purge silinoid control circut.
Where in the hell is the engine speed sensor on this, i found the cam & crank position sensors, but can't find in any componate location chart that tells where the speed sensor is.
I am shopping arround for a tech tool capable of handling the programming and calibration of the PCM,BCM & ECU type , any suggestions.
Take your time and read over this more than once because I know I get consfusing, & if you say it's time to, the BCM will be the next on the list to be replaced, or if you think we should check something else out first let me know.
P.S. bought the car for 600 & have about another 200 invested so far, so if I can get this all worked out for under 800-1000 I'll be ok.
Oct 4, 2009 at 11:14 AM
MATHIASO
  • 1,209 POSTS
Trouble Code: P0727
Engine Speed Circuit Low Input .
Possible Causes:
CAN bus circuit is open, shorted to ground or shorted to power TCM or PCM has failed
what do you think?
Oct 4, 2009 at 3:44 PM
F15ACTACE
  • 14 POSTS
[quote:945ad3b687="mathiaso"]Trouble Code: P0727
Possible Causes:
what do you think?[/quote:945ad3b687]
Well, first of all, the code P0727 is stored when there is 'no signal' detected, not low, the exact definition per Saturn is 'Engine speed no signal' However, anybody can look up what a code referances, often it is not the cause of the problem but the result of the problem. I have manufacture's code definitions, what I can't seem to find is step by step trouble shooting charts for this vehicle.
Peviously you had said,
"I checked it out, it is not CAN system on yhis car, the can system are on vehicle made from 2003, this one is 2001."
Now how can "CAN bus circuit is open" be a possible cause, if this is not a CAN system. Naturally, if there has been a "no signal" circut problem detected then it is safe to say there is an open circut somewhere but where?
I am also confused about the reply you made about the SRS brain box.
"if there is internal faillure as you said have it replace."
I want to make sure that you understand, I was not the one who determined internal failure. At some point I will confirm it by eliminating all other possibilities for the SRS light being on, I dont go ahead with repairs until there is no "if's".
As for what I think, I need to know where the sensor for engine speed is & how to test it's signal, check the circut so I can confirm wether or not it's at fault for code P0727 or if it's the module itself that has the circut failure resulting in signal loss.
Do you have access to componate location for the Engine speed sensor?
Oct 5, 2009 at 2:54 PM
MATHIASO
  • 1,209 POSTS
wow!! wow!!
I stand firmly by what I said to you.
there is no can system on 2001 vehicle.
In 1995, GM introduced its own "Class 2" data bus to handle communication between modules
GMLAN" (GM Local Area Network).I do not know if I can call this a can system.
Everything you need is there, included diagnosis and procedures.
Oct 5, 2009 at 7:36 PM
