Looking for a diagram of the relay/fuses electrical system
DHANASARSOOBHAG
  • 2011 AUDI A6
Trying to locate some relays/fuses for certain functions
Sunday, October 14th, 2012 AT 11:02 PM
  • 52,797 POSTS
Relay
Relay and fuse carrier in electronics box plenum chamber, left
Position of Relays, from model year 2005
1 - Not used
1.1 - Brake Booster Relay -J569-
1.2 - Coolant Circulation Pump Relay -J151-, Auxiliary Engine Coolant (EC) Pump Relay -J496- (3.2L engine)
2 - Fuel Pump (FP) Relay -J17-, Engine Component Power Supply Relay -J757- (3.2L engine)
2.1 - Fuel Pump (FP) Relay -J17- (Diesel)
2.2 - Not used
3 - Power Supply Relay (terminal 30) -J317- (Diesel), Motronic Engine Control Module (ECM) Power Supply Relay -J271- (Gasoline)
3.1 - Not used
3.2 - Not used
See diagram for plenum chamber location
Sunday, October 14th, 2012 AT 11:11 PM
TATIANA ACOSTA
  • 2006 AUDI A6
  • 3.2L
  • V6
  • TURBO
  • AWD
  • 173,000 MILES
Where is my radio fuse located on my car?
Sunday, August 18th, 2019 AT 10:45 AM (Merged)
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,110 POSTS
Hi TATIANA,
It is on the right side of the dash, here are a few diagrams that should help you.
It is under media player, please get back to us with your results.
Best, Ken
