2003 Pontiac Grand Prix brake lights
2003 PONTIAC GRAND PRIX
JLIV
Electrical problem
2003 Pontiac Grand Prix 6 cyl Front Wheel Drive Automatic
my brake lights quit working suddenly. the rear window brake light functions properly. I have checked bulbs and fuses. they are ok. all other lights are working properly. the brake light switch on the pedal has been checked and is ok also. any idea whatthe problem might be?
Jun 28, 2008 at 5:39 PM
BMRFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 19,053 POSTS
The two rear brake lights out
center brake light working
this should point you in the direction of checking and replacing the rear bulbs
make sure u are using the correct # bulb
and check wiring and signal switch
Jun 29, 2008 at 4:56 AM
