coolant temperature sensor?
2006 PONTIAC GRAND PRIX
97,000 MILES • 6 CYL • 2WD • AUTOMATIC
TRICE3KDS
how to replace the coolant temperature sensor on 2006 Pontiac grand prix?
Dec 20, 2010 at 7:02 AM
SATURNTECH9
  • 30,869 POSTS
ENGINE COOLANT TEMPERATURE (ECT) SENSOR REPLACEMENT
REMOVAL PROCEDURE
NOTE: Use care when handling the coolant sensor. Damage to the coolant sensor will affect the operation of the fuel control system.
1. Partially drain the cooling system. Refer to Draining and Filling Cooling System (LS4 Static Fill) Draining and Filling Cooling System (L26, L32 Static Fill) Draining and Filling Cooling System (GE 47716 Fill) in Cooling System. See: Engine, Cooling and ExhaustCooling SystemService and Repair
2. Disconnect the ECT sensor electrical connector.
3. Remove the ECT sensor.
INSTALLATION PROCEDURE
1. Coat the threads with sealer GM P/N 12346004 (Canadian P/N 10953480) or equivalent.
NOTE: Replacement components must be the correct part number for the application. Components requiring the use of the thread locking compound, lubricants, corrosion inhibitors, or sealants are identified in the service procedure. Some replacement components may come with these coatings already applied. Do not use these coatings on components unless specified. These coatings can affect the final torque, which may affect the operation of the component. Use the correct torque specification when installing components in order to avoid damage.
2. Install the ECT sensor.
NOTE: Refer to Fastener Notice in Service Precautions.
Tighten the ECT sensor to 25 N.m (18 lb ft) .
3. Connect the ECT sensor electrical connector.
4. Fill the cooling system. Refer to Draining and Filling Cooling System (LS4 Static Fill) Draining and Filling Cooling System (L26, L32 Static Fill) Draining and Filling Cooling System (GE 47716 Fill) in Cooling System. See: Engine, Cooling and ExhaustCooling SystemService and Repair
Turns out the 2006 Grand Prix (at least with the 3800) required the removal of part of the exhaust to even get to the sensor.
Dec 20, 2010 at 12:55 PM
CAMARO_74
my 04 pontiac grand prix gt egine cooling fans turn on late. i changed the coolant temp sensor but still the same. the temp gauge reads a little over 3/4 of the way when the fans turn on. what else can be the cause for this.
Sep 11, 2020 at 4:53 AM (Merged)
Could be the computer controlled of the relay-also try replacing the engine thermostat and see what happens it controls the engine temperature sensor.
CAMARO_74
I changed the thermostat and its still the same. The fans don't come on til after the temperature is between the 3/4 and the red zone. Could it be the fan relay
Try swapping it with a like one and see what happens-don't work double check wiring at the CTS, Fan relay-if okay could be the computer control circuit of the relay-
DELTA101089
I'm having an issue with my engine overheating and am replacing the thermostat and sensor. I've located the thermostat but where is and how do you replace a coolant temperature sensor?
HMAC300
  • 48,601 POSTS
there is a sensor right by the thermostat. But there may be 2 1 for the computer and the other for the fan. i't s a simple disconnect the wiring harness and unscrew it and put another in.
CHUKER1959
My Service Engine light came on. I took car to Auto Zone they hooked it up to the machine and told me my Coolant Temperature Sensor was bad. I have located the part at the dealer and surprisingly it isn't too expensive.
I need to know where this sensor is located on my vehicle so that we can replace it. Is this a job that we can do ourselves?
Yes you can do it-look below its for a 3.8 liter engine.
https://images.2carpros.com/forum/automotive_pictures/12900_cts_4.jpg
CRAIGPLURIE
What steps are required to change the low coolant sensor on my 2002 pontiac Grand Prix? Due to the location of the sensor in the radiator I am worried there is more to replacing the switch than just taking it out and putting a new one in and replacing the lost fluid.
ZACKMAN
  • 4,202 POSTS
That is it. You are over-thinking it. Relax.
https://images.2carpros.com/forum/automotive_pictures/55316_02gpcoolant_1.jpg
RICKEYHART
where might the sensor be located on my vehicle
MERLIN2021
  • 17,250 POSTS
It's on the top left rear of the engine below the throttl body.
https://images.2carpros.com/forum/automotive_pictures/62217_ECT38_1.jpg
