Blower motor resistor is located on the blower motor case itself. Blower motor is located under dash, remove right lower interior panel for access.
REMOVAL/INSTALLATION:
Disconnect negative battery cable.
Disconnect resistor wiring harness.
Remove resistor mounting screws, then resistor.
Reverse removal procedure for installation.
SPONSORED LINKS
Thursday, November 27th, 2008 AT 11:56 PM
