2001 Bonneville SSEi leaking condensate onto pass side floor
2001 PONTIAC BONNEVILLE
ES347FAN
2001 Pontiac Bonneville SSEi, 80,000 miles, wife's daily driver, primarily interstate miles (35 one way) into Atlanta & back. About a week ago began leaking water - not radiator coolant - into the passenger footwell, saturating carpet. Pulled the carpet back, dropped one panel (2 screws) from beneath the glove compartment, no obvious leaks. A/C blows real cold, condensate does drip from beneath the vehicle when parked. Checked the cabin air filter, it's clean & dry.
Thoughts?? Any assistance would be appreciated.
Aug 15, 2006 at 2:12 PM
WEAREA2J2
  • 43 POSTS
there may be junk (leaves, dirt, etc.) in the condesate pan under the evaporator coil. This could partially block the drain. Try to clean the pan and see if that helps. I had a semi that did the same thing and I put a straightened clothes hanger into the end of the drain tube. It worked for me. Just be careful not to damage the coil. Good Luck!!!
Aug 15, 2006 at 10:17 PM
