1999 Pontiac Bonneville WATER LEAKAGE
1999 PONTIAC BONNEVILLE
ROSEANN
Interior problem
1999 Pontiac Bonneville Front Wheel Drive Automatic 118000 miles
when it rains for long periods of time, i get ALOT of water build up in the back seat passenger floor area-specifically the center not the sides. there is no trace of water anywhere else in the car or surrounding areas of the back seat. there is no hole underneath or water in the trunk. it is a mystery. please help.
Apr 30, 2008 at 10:29 AM
SUSMAN28888
  • 62 POSTS
did you check the roof, alot of times in bonnevilles there are drains inside the roof of your car for the sun roof, that go down the side of the car and drain right below where your speaking off, and it might be clogged. Id also check to make sure the seal frame center knotch is not over lapped and leaking
May 1, 2008 at 8:54 PM
