Fuse box?
ABADGER
  • 1999 PONTIAC BONNEVILLE
  • 6 CYL
  • 67,000 MILES
My cigarette lighters no longer work. I assume that iit is a blown fuse but I do not know where the fuse box is located. Also how do I know which fuse to change out.
Thanks
Thursday, December 3rd, 2009 AT 11:18 AM
  • 108,289 POSTS
Here is a guide to help you test the fuses and the fuse panel diagrams listed below.
Wednesday, December 16th, 2009 AT 8:07 AM
MSHABAZZ
  • 1997 PONTIAC BONNEVILLE
Electrical problem
1997 Pontiac Bonneville 6 cyl
we removed the starter and it was not the problem so now I need to know where fusible link is and here is an overview of what is going on the car will not start no cliking no nothing the power still comes on but nothing else as far as the engine
Friday, July 17th, 2020 AT 12:23 PM (Merged)
JDL
  • 16,098 POSTS
Hi, possibly theft/security system? If there is a security lite on the dash that is on or flashing, when you try to start, have the security system checked out.
JDSGIRL83
  • 1996 PONTIAC BONNEVILLE
  • 6 CYL
  • FWD
  • 17,932 MILES
My car is used and the only owners manual with the car was a 1995 manual for a bonneville, so now I need to know what all the fuses go to in the fuse box, because most of the fuses are not there, but my doors lock automatically, when my car sit's overnight. And Ido not know what my fuses go to in the fuse boxatly appreciated. I have no credit card so I am unable to donate any money at this time, but I sure would appreciate your help.
See below
Left I/P fuse block:
https://www.2carpros.com/forum/automotive_pictures/12900_fuse1_1.jpg
Right I/P fuse block
https://www.2carpros.com/forum/automotive_pictures/12900_fuse2_1.jpg
See the diagrams below for the location of the power centers for your vehicle
Let us know if you need anything else
JDSGIRL83
Thank you for the fuse box information, althouh which fuse box is the one under my dash, is it considered the left or right fuse box, thats what I am needing to know also, thank you again very much for your help
MSSMITH
  • V8
  • 100,000 MILES
Where is the fuse box located
Friday, July 17th, 2020 AT 12:24 PM (Merged)
2CARPRO JACK
  • 11,533 POSTS
There are several fuse blocks in this vehicle
See the guide below on testing fuses with a test light
See the diagrams below for locations
CARREPAIRKLL
  • 1995 PONTIAC BONNEVILLE
  • 6 CYL
  • FWD
  • 180,000 MILES
Where are the fuses for the power seats in a 1995 bonneville SSE
BLUELIGHTNIN6
  • 16,542 POSTS
Fuse #3 (25 amp) in the fuse panel
PM296
  • PONTIAC BONNEVILLE
1994 pontiac bonneville 3.8
I need to check the fuses but where are they located?
SERVICE WRITER
  • 9,123 POSTS
On the left side of the dash, Not sure if it is behind a panel on side of the dash, exposed when the door is open; or may be under the dash on the left.
RANGER4520
There is another fuse box on the pasenger side with more relays right behinde the dash. You have to take and pull the bottom cover off and take the glove box out also just to see them
1990SSE
  • 1990 PONTIAC BONNEVILLE
  • 6 CYL
  • FWD
  • 152,000 MILES
I was driving at night when I noticed my dash and taillights where not on. After checking fuses and finding that was the problem, I changed the fuse and continued. Shortly after, I started to smell burning and all my lights (interior and exterior) started to flash and flicker. The vehicle still runs, but I cant seem to find the problem, plus I am at a loss of where to even start.
JDL
  • 16,098 POSTS
Hello, what fuse did you replace, was it blown? That circuit maybe shorting to ground, pull the fuse. If that was the tail fuse, it shouldn't go hot till you turn on the lites.
I just wanted to add, the dash and tail-lites may use the same fuse. You can use a test-lite as a load on that circuit, it won't blow the fuse and maybe it won't melt the wire. If that is the problem circuit.
1990SSE
The fuse that blew was the tail light fuse. I repaced the fuse and all the lights started flashing and thats when I smelled the burning. I then removed said fuse and the flashing and burning continued.
JDL
  • 16,098 POSTS
You might try unplugging the headlite switch, see if the flashing/burning goes away. My wiring diagrams doesn't show the feed circuits for the fuse on this vehicle.
SEANDRA123
  • 1993 PONTIAC BONNEVILLE
  • 6 CYL
  • FWD
  • 11,000 MILES
I need to know the complete fuse diagram for a 1993 pontiac bonneville
Fuse & Circuit Breaker Identification
1 - Blank or Spare
2 - Blank or Spare
3 - 10 Amp (1987) Radio; Blank (1988-91)
4 - 25 Amp (1987) Windshield Wiper; Blank (1988); 10 Amp (1989-91) Radio
5 - Blank (1987); 10 Amp (1988) Windshield Wiper; 25 Amp (1989-91) Windshield Wiper
6 - 20 Amp (1987) Cooling Fan Relay; 5 Amp (1988-90); 10 Amp (1990-91 SSE Model) Cooling Fan Relay
7 - 25 Amp; 15 Amp (1990-91 SSE Model) Air Conditioner
8 - Blank (1987); 5 Amp (1988-89) Electronic Brake System (Pump); 5 Amp (1990); 10 Amp (1990-91 SSE Model) Electronic Brake System (Control)
9 - 15 Amp (1987) Electronic Vacuum Regulator Valve (EVRV), Canister Purge, Engine Relays; 5 Amp (1988-89) Electronic Brake System (Control); 5 Amp (1990); 10 Amp (1990-91 SSE Model) Electronic Brake System (Pump)
10 - 20 Amp (1987) Fuel Pump Injectors; 10 Amp (1988-89) Cluster, Oil, Compass; 10 Amp (1990-91) Low Coolant, Compass; Blank (1991 SSE Model)
11 - 20 Amp (1987) Taillights; 20 Amp (1988) Radio, Cigarette Lighter, Underhood Light; 20 Amp (1989-90); 15 Amp (1990-91 SSE Model) Chime, Cigarette Lighter, Radio, Power Antenna
12 - 20 Amp Electronic Ride Control
13 - 20 Amp Stoplights (1987-90), Brake & Hazard Lights
14 - 20 Amp (1987) Radio, Cigarette Lighter, Underhood Lights; 20 Amp (1988-89) Taillights; 20 Amp (1990); 15 Amp (1990-91 SSE Model) License Plate Light
15 - 20 Amp (1987-88) Dome Light; 20 Amp (1989) Courtesy Light, Power Mirror; 20 Amp (1990-91); 15 Amp (1990-91 SSE Model) Courtesy Lights, Power Mirror & Locks
16 - 20 Amp (1987-88) Gauges, Generator Light; 20 Amp (1989) Door Locks, Illuminated Entry System; 20 Amp (1990); 15 Amp (1990-91 SSE Model) Gauges, Illuminated Entry System, Anti-Theft (1991)
17 - 10 Amp Electronic Control Module (ECM), Computer Command Control; 20 Amp (1990-91 SSE Model) Trunk Relay
18 - 5 Amp; 10 Amp (1990-91 SSE Model) Cruise Control
19 - 15 Amp; 20 Amp (1990-91 SSE Model) Turn Signals, Back-Up Light
20 - 20 Amp Electric Trunk & Fuel Door Release; 10 Amp (1991 SSE Model) Instrument Panel Lights
21 - Blank or Spare
22 - Blank or Spare
23 - 30 Amp Circuit Breaker (1987-88) Power Windows; 30 Amp Circuit Breaker (1989-91) Power Windows & Sun Roof
24 - 30 Amp Circuit Breaker (1987-88) Power Seats, Rear Window Defogger; 30 Amp Circuit Breaker (1989-91) Power Seats & Door Locks, Rear Window Defogger
25 - 5 Amp; 10 Amp (1990-91 SSE Model) Instrument Panel Lights (1987-90), Low Coolant (1991), Compass (1991), Driver Information System (1991)
26 - 10 Amp (SSE Model Only) Spare (1988), Radio & Accessories (1989), DIC (1990-91)
27 - 10-Amp (SSE Model Only) DIC (1988-89), Heated Mirrors (1990-91)
28 - 15 Amp (SSE Model Only) Heated Mirrors (1988-89), Courtesy Lights (1990-91)
29 - 20 Amp (SSE Model Only) Spare (1988-89), Horn (1990-91)
30 - 15 Amp (SSE Model Only) Instrument Panel (1988), Engine Relays (1989-91)
31 - 20 Amp (SSE Model Only) Fuel Pump
32 - 10 Amp (SSE Model Only) Injection
