Engine runs rough and smooths out as the engine warms up.
Friday, January 6th, 2012 AT 11:15 PM
HMAC300
MECHANIC
441 is a evap code meaning it's not getting vacuum or the cannister is messed up 450 is evap as well but could mean the ecm is bador thhe valve is bad. If the canister isn't getting vacuum, fix it and clear the codes as that may cause both.
SPONSORED LINKS
Saturday, January 7th, 2012 AT 12:45 AM
TOYOTA GUY
MEMBER
Would either error codes cause the engine to run rough (like a piston is not firing) than smooth out a few munites later (like all is fine with the engine)
Saturday, January 7th, 2012 AT 12:49 AM
HMAC300
MECHANIC
If you have a vacuum leak yes that's why I said to check to see if the system is leaking vacuum like aline off. You will have to clear the codes after fixing the problem.
Saturday, January 7th, 2012 AT 12:53 AM
TOYOTA GUY
MEMBER
Where is the charcole canaster on the T-100?
Saturday, January 7th, 2012 AT 12:55 AM
HMAC300
MECHANIC
By the gas tank
SPONSORED LINKS
TOYOTA GUY
MEMBER
Along with the vacuum lines?
Saturday, January 7th, 2012 AT 12:56 AM
HMAC300
MECHANIC
Here is a pic of 3.4L engine. You didn't give engine size so others will be similar easy to look for.
Image (Click to make bigger)
Saturday, January 7th, 2012 AT 1:01 AM
EXTREAMHELIS
MEMBER
Did. You ever figure this out I have the same problem?
Thursday, August 10th, 2017 AT 9:52 AM
KEN L
MASTER CERTIFIED MECHANIC
The user never got back to us on this so we will need to find out whats going on. Here is a guide that will help us start some easy testing.
