Crank shaft pulley off of the car?
ANONYMOUS
  • 1997 PLYMOUTH BREEZE
  • 130,000 MILES
I am trying to change the timing belt on my car. It is a 1997 Plymouth Breeze. I cannot get the crank shaft pulley off of the car. Can you please tell me how to remove the pulley?
Friday, October 26th, 2012 AT 2:58 PM
KHLOW2008
  • 41,815 POSTS
After removing the central bolt, evenly pull on the pulley to get it off. sometimes it gets stuck and some WD-40 with a little tapping from rear of pulley should get it off. Try to evenly pull on the pulley, shaking it lightly if necessary. This video will show you how on a similar car
https://youtu.be/NZIMNkLxCMA
Friday, October 26th, 2012 AT 3:06 PM
TINYTIM77
Needs a special tool that can be loaned from autozone, harmonic balancer puller 3 jaw type. Also yuu will need somthing to stop the pully from turning while you turn the puller bolt. I have done this twice, timing belt and cam seal 96 breeze 2.0 sohc. Not easy
Wednesday, March 6th, 2013 AT 5:30 AM
JMG724
  • 4 CYL
  • FWD
  • 164,000 MILES
How do I remove the Crank Pulley? I have tried 3 different types of Pulley Pullers none have worked and the ony thing that I have a accomplished is destroying the pulley itself. Plz help.
Friday, September 11th, 2020 AT 11:24 AM (Merged)
  • 31,937 POSTS
Hi there,
The instructions for removing the pulley call for special tools, see text for No... i am looking for a pic as well.
Mark (mhpautos)
https://www.2carpros.com/forum/automotive_pictures/61395_Noname_43.jpg
WALLUS
  • 13 POSTS
These are pictures I've come up with.
I made my own tools except for the three jawed puller
https://www.2carpros.com/forum/automotive_pictures/297008_78257318_1.gif
https://www.2carpros.com/forum/automotive_pictures/297008_78257319_1.gif
