Engine no crank, anti theft light on steady?
DNDRRICH
  • 1997 CHEVROLET CAVALIER
  • 4 CYL
  • 200,000 MILES
97 cavalier ls, 2.2, 4 speed auto, wont crank tried to reset anti theft by trying to start engine and leaving key in on position ten minutes, no luck.
Friday, February 18th, 2011 AT 1:53 AM
SATURNTECH9
  • 30,869 POSTS
Does the starter turn the engine over?Also let me know if this is what you tried to reset it. If any of these parts are replaced, the vehicle may start and stall for 10 (ten) minutes (LONG TAMPER MODE). If this occurs, the system MUST go through a LONG TAMPER MODE cycle. During this time, the THEFT TELLTALE will be flashing for the full ten minutes. The IPC and PCM require the full ten minutes to complete a learn cycle. The Ignition Key MUST remain in the "RUN" position until the telltale stops flashing or the cycle will have to be repeated.
Here is a guide to help you reset the system by doing a hard reboot.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Please run down this guide and report back
Cheers
Friday, February 18th, 2011 AT 2:00 AM
DNDRRICH
The starter does not ingage, no click.
Yes the restart senario you describe is correct howevere the anti theft is on even after the other instruement panal lights go out.
Saturday, February 19th, 2011 AT 12:54 AM
SATURNTECH9
  • 30,869 POSTS
I looked up the factory anti theft on your car and when it engages it doesn't disable your starter it's disables your fuel injector's from getting fuel to the engine. So the starter being inop is the problem or a different problem. So let's start by getting your starter working and see if it start's then. First thing I want you to do is have your battery tested and make sure both your battery cable's are clean and tight. After you do that we will start tracing power from your ignition switch to your starter. Here is a description on how your anti theft work's.
The PASSLOCK System is designed to prevent vehicle operation if the mechanical key is not used to start the vehicle. The mechanical key, in normal operation, will turn the PASSLOCK Lock Cylinder. The PASSLOCK Lock Cylinder will relay a Resistance Code (R-Code) to the Instrument Panel Cluster (IPC). The IPC will determine the validity of the R-Code within a preset time window started from an Ignition Switch input and will send a coded password to the Powertrain Control Module (PCM). When the PCM receives the correct code, it will allow the Fuel Injectors to operate normally.
Saturday, February 19th, 2011 AT 1:09 AM
DNDRRICH
Cleaned battery tirminals. 12.5v at battery, engine ground pulled 12.2v at engine block. Battery holds charge.
Saturday, February 19th, 2011 AT 2:19 AM
SATURNTECH9
  • 30,869 POSTS
The only true way to test a battery is to have it load tested. But we can still do some checking I would just leave the battery in question if it's good. Go to the neutral safety switch and have someone hold the key in the start position and see if you have battery voltage to the yellow wire and then check the purple wire on the neutral safety switch they should both have battery voltage with the key in the start position. Let me know what you find.
Saturday, February 19th, 2011 AT 2:47 AM
DNDRRICH
I found out the two small wires from the ignition tumbler had broken once I fixed it the car started have not had a problem since, did need to remove the steering wheel and backing plate to do the job. Thanks for your help.
Saturday, February 19th, 2011 AT 7:56 PM
SATURNTECH9
  • 30,869 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help
Cheers
Sunday, February 20th, 2011 AT 5:36 AM
FARR2007
  • 210 POSTS
  • 220,000 MILES
I was driving down the road at a bout 40 miles per hour gaining speed, when all of a sudden the car just died, I tried to start it but it just cranks over and dont start, also the anti theft wont go off, it stays on always and dont blink, I had to replace lock cylinder because my old one jammed up, car worked fine for months and now it isnt working. Please help
Thursday, July 1st, 2021 AT 10:29 AM (Merged)
SATURNTECH9
  • 30,869 POSTS
We cant give out info on how to bypass factory anti theft systems.I can help you figure out the problem though.I have never seen a failed anti theft system to cause the car to die while driving. Check out this guide
FARR2007
  • 210 POSTS
I forgot to mention that also if you spray starter fluid into the throttle body it will not run either, I checked spark plugs and they get spark, what can you do to help me figure this out
SATURNTECH9
  • 30,869 POSTS
Thats strange that it wont start on starting fluid and it has spark. Have you checked for codes yet?
FARR2007
  • 210 POSTS
It was the computer, I got used one it fired right up thank you.
TXSLINDSEY
  • 4 CYL
  • 58,000 MILES
The car will start and then just shut off. The theft light comes on and I have to wait about 10 minutes till I can start it. Is their an easy way to fix this? And if so how?
MMPRINCE4000
  • 8,548 POSTS
GM Pass lock relearn
Ignition to "run" position, try to start and let key return to "run" position
Approx ten minutes security light will go off
Turn key "off" and wait 5 seconds
Repeat 2 more times for a total of 3 relearns.
Turn key off, then start it
RUCANADIAN
  • 4 CYL
  • FWD
  • 229,000 MILES
Hi thanks for taking the time to hopefully help me out,
i recently changed my starter, but before that I took the battery out for more than 24 hours, when I finally was done installing the new starter, I installed the battery, then when I went to start the car, it turned over but no start. I noticed the theft system light was 'on', not blinking, I called a few people, and they kept saying the same thing, put the key on for 10 min, then start, but nothing, then I called gm, and the said' start it, but leave it on for 40 min and then turn off and try to start it, but nothing.
What can be causing this problem? Please help me
thank you
MMPRINCE4000
  • 8,548 POSTS
Turn key on
security light flashing
try to start and let go leave key on
security light flasher for about 10 min
when it stops
turn key off and start car
key needed to be reprogrammed
in some rear cases you may have to do that 3 times total of 30 min
TXSLINDSEY
I have the same problem and I have done this whole leave the key forward for ten minutes and when the light stops flashing then start it.I have to do this almost every time I start my car. It has been doing it for a week. So that is way more that 3 times. Why isn't my key being reprogrammed?
2CP-ARCHIVES
  • 4,540 POSTS
  • 180,000 MILES
Car dies after 2 or 3 seconds theft light stays on with numerous other lights how do I fix this
HMAC300
  • 48,601 POSTS
Check battery condition including load test then try resetting anti theft. See attached.
DANNIBOI95
  • 1996 CHEVROLET CAVALIER
  • 2.4L
  • 4 CYL
  • 143,000 MILES
I have the car listed above z24. The car starts and shuts off due to Pass-lock. My theft light is on, but not flashing, it is solid. I have tried ten minute and thirty minute relearn procedures, but the theft light never goes out, and Pass-lock is still active. What can I do to get my car driveable again?
Thursday, July 1st, 2021 AT 10:30 AM (Merged)
