1989 Oldsmobile Cutlass Where is the ignition module locate
JUMPERFREE
  • 1989 OLDSMOBILE CUTLASS
Engine Mechanical problem
1989 Oldsmobile Cutlass 6 cyl Two Wheel Drive Automatic
where is the ignition module located and how do I test if it works o.K.
Do you
have the same problem?
Thursday, June 3rd, 2010 AT 2:15 PM
INTERNETMECHANIC
Olds cutlass what? My database shows several cutlass. If dis ignition, it is under the coil pack. If you have a distributor, it is in the distributor. Any applicable trouble codes? I need more information? Exactly what is the problem?
Thursday, June 3rd, 2010 AT 2:31 PM
Recommended Guides
