2004 Oldsmobile Alero A/C
2004 OLDSMOBILE ALERO
57,000 MILES • 6 CYL • FWD • AUTOMATIC
DENNISTHEABBOTT
When the a/c is turned on engine RPM increases & dash,steering wheel ,etc. start vibrating.When a/c is turned off,vibration stops. I think the compressor is going out & is dragging,causing strain on the engine as it drives the pulley.I'm hoping it may just be the clutch bearings.Can I replace the clutch without discharing the unit? I do not have a vacum pump & other tools needed for a complete compressor swap.
Mar 22, 2008 at 9:28 AM
RHALL77
  • CAR REPAIR CONTRIBUTOR
  • 3,361 POSTS
yes you can replace the clutch but the bearings are inside the compressor. I would suggest taking it to your local shop or dealership.
Mar 27, 2008 at 12:54 PM
DENNISTHEABBOTT
Turns out the problem was with the a/c blower motor. Apparently a rat had found a poison bait cube & stored it inside the blower.When the fan was turn up past the lowest speed, the cube would cause the motor to spin out of balance & cause the vibration & noise. I'm still trying to find out how he was able to get inside the a/c ducting.This is an 04 Alero in showroom condition.This bait cube is about 3" long x 1.5 " diameter.
Mar 28, 2008 at 6:38 AM
