Engine oil leak?
ANONYMOUS
  • 2007 NISSAN XTERRA
  • 65,000 MILES
I think I have an oil leak how can I find it?
Sunday, February 3rd, 2013 AT 7:07 PM
  • 52,797 POSTS
Oil drain plug, oil filter, oil pressure switch, rear main oil seal, front oil sea along with cam seals
The guide can help
https://www.2carpros.com/articles/engine-is-leaking-oil
Sunday, February 3rd, 2013 AT 7:36 PM
CAB712
  • 2001 NISSAN XTERRA
  • 110,000 MILES
It has an oil leak near the oil pan. Is the work on this extensive or expensive? I personally think its the gasket, but if its not expensive I would take it to a pro.
Monday, November 11th, 2019 AT 6:48 PM (Merged)
FIXITMR
  • 9,990 POSTS
It can be just a oil pan drain plug here is a guide to help you see whats going on.
CAB712
I am at college at the moment and do not have a picture. I drove the vehicle for 3 hours tom get home from the place I bought it the it was originally like a quarter sized drip the day I bought it and I parked it in the garage this weekend to come to find about a 1ft round puddle directly under the oil pan. If the work doesn't involve removing the tranny and what not my father and I can most likely do it I just don't know enough about the vehicle to dive in. Apparently I should of known more about the slimy salesman too.
  • 31,938 POSTS
See text for removal.
FIXITMR
  • 9,990 POSTS
Hopefuly it is not a rear main seal leak! You need to actually locate it. Leaks can run down from higher places too.
KHLOW2008
  • 41,815 POSTS
The oil pressure switch is prone to leaks and if that is the case, that would be the cheapest fix. Apart from that, most other repairs are not going to be cheap.
Monday, November 11th, 2019 AT 6:49 PM (Merged)
JR47
  • 98 POSTS
  • 3.3L
  • V6
  • 186,733 MILES
The leak appears to be coming from where the engine and transmission meet and its a fairly decent leak. I have looked around and there are no other oil leaks except from here, also is the little opening on the housing supposed to be there? Only asking because judging by the edges it appears a piece has broken off.
HMAC300
  • 48,606 POSTS
Is it engine oil or transmission? If it is engine it may be a rear main seal which means the transmission has to come out to repair it or there may be an oil sender on top of block leaking and coming down.
JR47
  • 98 POSTS
Its definitely engine oil. If it is any help the drop of oil you can see in the photo I did watch it seep out between the housing and the thin metal plate that comes right after it.
HMAC300
  • 48,606 POSTS
As I said in first reply check for oil leaks on tops dripping down then check the rear main seal which will require pulling transmission to fix.
