When I replaced the PCM in the car it had oil in it. Now the oil has traveled through the wiring and for sure has reached the OBDII connector.
The problems i am having :
While driving the car the speed odometer will just stop working. Sometimes the dash gauges will go crazy when the headlights are turned on. Recently the car started missing and hesitating.
Is there a way to remove the oil from the wiring without doing a total rewrire on the car?
Dec 13, 2017 at 12:16 AM
