2003 Nissan Sentra Vibration noise when car is warm around
2003 NISSAN SENTRA
140,000 MILES • 4 CYL • FWD • MANUAL
JCARD503
  • 7 POSTS
I have a loud vibration noise on my 2003 nissan sentra spec-v around 2000rpm when warm.
Does not matter if the car is stopped or moving,
in gear or out of gear.
Taken to 6 different mechanics, half say heat shields
the other half say internal inside my engine.
-So I start my car no noise
-I drive untill car warms up
-sitting in neutral rev car up to 3000rpm on rev-down
around 2000rpm car makes loud annoying vibration noise
-I can make the same noise driving around 2000rpm or just sitting there with foot on gas peddle
-car makes noise between 1900-2100rpm
+I have removed all heat sheilds noise still there
+I have a new engine in car with about 25000 miles on it
+taken it to master exhaust places they had there master tech listen to the car for about 2 hours with a stethoscopes and he claims noise is comming from oil pan or around that area
+Nissan master oregon tech who is one of the best techs on nissans in the country as nissan claims says its the exhuast sheilds I took them all off and I replaced hangers tightend bolts everything Nothing loose....
I dont think I left anything out but after spending 5000.00 for a new engine I am not so happy about choosing a nissan.....
Mar 27, 2010 at 12:39 AM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
Hi jcard503,
Thank you for the donation and sorry to hear about the amount of time and $ that you have put into this.
Was the catalytic converter checked? Quite often the cat converter becomes detached internally and this would cause vibration noises.
Did this problem occurred immediately after replacement of the engine?
Mar 27, 2010 at 6:05 PM
JCARD503
  • 7 POSTS
Yes it was hammered on by a rubber mallet no noise and I allready had the pre-cat problem happen to my engine...
And no it happened or noticed about 15,000 miles had been put on it
Mar 27, 2010 at 9:16 PM
JCARD503
  • 7 POSTS
and wouldnt the cat make the sound all the time not just when warmed up after like 10min of driving?
Mar 27, 2010 at 9:22 PM
KHLOW2008
  • 41,814 POSTS
The cat is subjected to high temperatures and when cold the parts could be snug. The heat can cause the internals to loosen up thus the noise.
When the noise occured, was the cat checked then?
Mar 28, 2010 at 1:15 AM
JCARD503
  • 7 POSTS
ok I will this time remove my cat and see if thats what it is but it has been hammered on several times
Mar 28, 2010 at 10:08 AM
KHLOW2008
  • 41,814 POSTS
If it is engine internals, the noise should be present at all temperature conditions so I would suspect it to be external.
Let me know what you find.
Mar 28, 2010 at 10:22 AM
JCARD503
  • 7 POSTS
k I took the cat off no pieces fell out.... Looks and sounds solid.
Also wouldnt I hear the cat at all rpm's its very specific where you would not be able to make the sound unless shown how....
Also wouldnt the engine noise be heard once warm with the change in engine oil velocity?
I am kinda out of ideas... Its to the point where all mechanics are saying its internal and others saying extrenal.... They said they will tear apart the engine and if it is the engine they will replace. And if its not the engine I need to pay for it....
Exhaust was my first guess to But the vibration noise is horable sounding
Mar 28, 2010 at 12:12 PM
KHLOW2008
  • 41,814 POSTS
For CAT noises, it can appear only at specific engine rpms.
Without the physical, it would not be possible to diagnose such noise problems.
You have a dilemma that is not going to be easy to resolve.
Engine internals should not cause vibration noise. apart from the noise, is there any performance issues?
Mar 28, 2010 at 1:49 PM
JCARD503
  • 7 POSTS
no problems at all thanks for all the help I do understand what you are saying
Mar 28, 2010 at 2:36 PM
KHLOW2008
  • 41,814 POSTS
You're welcome and sorry for not being of much help to you.
Have a nice day.
Mar 28, 2010 at 2:46 PM
K.VANDIFORD
  • 5 POSTS
i can tell you exactly what the problemawas. i know from experience that not all flywheels on these cars were made the same. some of the cars flywheels have fewer teeth thanthe other ones. what happens by cause of this is that it puts a imbalance in the flywheel and the bolts tend to back out. the only way that this can be fixed is by pulling the tranny or the engine and loostening the bolts off one at a time and putting locktite on them. once they have been torqued they need to be tightened an extra 45 degreese.
Mar 28, 2010 at 4:22 PM
JCARD503
  • 7 POSTS
does it matter if I have no after market on the car all nissan products from nissan the flywheel and clutch where replaced about 14-18 months ago
Mar 28, 2010 at 10:59 PM
2 LINSEY
  • 287 POSTS
Hi jcard503,
Thank you for using 2CarPros.com. We appreciate your donation and look forward to helping you in the future.
Apr 1, 2010 at 4:48 PM
