1996 Mercury Sable
PALEMON
  • 1996 MERCURY SABLE
1996 Mercury Sable Engine Size unknown Wheel Drive Type unknown Automatic 125000 miles
were it is and how to change thermostat
Saturday, December 29th, 2007 AT 2:21 PM
MERLIN2021
  • 17,250 POSTS
Let the engine cool off, then drain it down about a gallon, there is a draicok on the bottom of the radiator, then follow the upper radiator hose to the engine, there you will find the thermostat at the end of the hose, unbolt the two bolts. Leave the hose attached to the housing. Scrape old gasket from both mating surfaces, install new thermostat, spring towards the engine. Install the gasket, snug the housing bolts! Not to tight and bring the housing down evenly. Refill the coolant and that's it!
Saturday, December 29th, 2007 AT 2:45 PM
Related General Content
