1996 Lincoln Mark VIII High Idle
1996 LINCOLN MARK VIII
140,000 MILES • V8 • 2WD • AUTOMATIC
47CARMEL
I r&r Intakes IMRC controls and replaced one actuator. Upon engine start up idle will not come down and continues to rise. I disconnected IAC but speed did not drop. IAC opening in throttle body draws alot of air, if I shut it down with rag engine will slow down. Is this the only item that could cause this extremely high idle?
Jan 10, 2008 at 3:53 PM
BLACKOP555
  • CAR REPAIR CONTRIBUTOR
  • 10,386 POSTS
take off your iac and make sure the pintle is moving freely.
Jan 10, 2008 at 8:53 PM
