1998 Jaguar XJ8 car turning over, then stalls
1998 JAGUAR XJ8
13,000 MILES • V8 • FWD • AUTOMATIC
KMCGARTHA8655
I had an accident and was hit from behind. Car turns over and then stalls. Fuel switch has been reset, but no result. Since reset car will not turn over. Is it possible that the timing jumped due to the impact? Could it be the fuel pump or fuel cut off relay?
Apr 15, 2010 at 11:44 AM
DAVE H
  • CAR REPAIR CONTRIBUTOR
  • 13,384 POSTS
Hello .. thanks for the donation .. much appreciated
Reset the inertia fuel cut off switch again..see if it starts firing up again .. sounds like the alarm/immobolizer may be tripped lock and unlock the doors a few times to reset the immo system .. the timing should not jump due to a collision !
hope this helps
Apr 16, 2010 at 3:35 AM
