Radiator replacement instructions needed
RAZZOCAMRICH
  • 2002 BUICK CENTURY
  • 100,000 MILES
I need to know how to replace a radiator and thermostat.
Saturday, May 8th, 2021 AT 12:52 PM
  • 52,797 POSTS
Good afternoon,
I attached the procedure for the radiator and thermostat replacement below for you to view.
https://www.2carpros.com/articles/how-to-replace-a-car-radiator
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Saturday, May 8th, 2021 AT 4:39 PM
RAZZOCAMRICH
Thanks ASEMASTER6371. That helped out a lot. I appreciate the help.
Saturday, May 8th, 2021 AT 9:02 PM
  • 52,797 POSTS
You are welcome.
Always glad to help.
Sunday, May 9th, 2021 AT 5:10 AM
ROCHELLE STEINHILB
  • 1999 BUICK CENTURY
  • 3.1L
  • 6 CYL
  • FWD
  • 125,000 MILES
How long should it take to replace a radiator? It has a hole in the side plastic part.
Wednesday, May 26th, 2021 AT 12:26 PM (Merged)
CARADIODOC
  • 33,757 POSTS
"Flat rate" is listed at 2.2 hours. That does not include additional services, removing broken bolts, antifreeze, etc. Often when cars get to be this age, the jobs are billed on the straight time it actually takes. That is because fasteners can break, electrical connectors and terminals may need to be repaired once they are disturbed, and things like that. A conscientious mechanic who has your best interest at heart will want to replace the radiator hoses at the same time, since they are already partially removed. He will also want to use new antifreeze unless the old stuff is not very old. The critical additives in it wears out in about two years, and reusing the old stuff can lead to corroded and leaking heater cores and radiators. This is already a real common problem on GM products that use the red Dex-Cool antifreeze.
