Camshaft position sensor located?
MSMUCHA
  • 2005 HYUNDAI SONATA
  • 100,400 MILES
Where is the camshaft position sensor located on a 2.7L V6 2005 Sonata. I've been hunting the WWW for an answer with no success. Help! Would like a clear diagram of where the camshaft position sensor is located on a 2.7L V6 2005 Sonata
Thursday, January 26th, 2012 AT 5:56 PM
DOCFIXIT
  • 18,828 POSTS
It is buried under fuel hoses and vacuum lines follow top radiator hose to engine under fuel line between air cleaner box and head. Here is a guide to help you see what you are in for when doing the job with diagrams below to show you how on your car.
https://www.2carpros.com/articles/camshaft-angle-sensor-replacement
Here are diagrams of where it is in your car. Check out the diagrams (Below) Please let us know what you find
Thursday, January 26th, 2012 AT 7:12 PM
MSMUCHA
Thanks. It looks like a real pain to get to. Is this something a person like myself, who can change an O2 sensor, attempt to replace?
Friday, January 27th, 2012 AT 4:16 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,055 POSTS
Yep you can get in there and do the job I will just take a little time. Please let us know if you need anything else to get the problem fixed.
Cheers, Ken
Monday, February 12th, 2018 AT 3:15 PM
DARLENE WILLIAMS
  • 2001 HYUNDAI SONATA
  • 2.4L
Replacing cam sensor, plug end is broken off, need to find order of wires from top to bottom, 3 wires, pink, black, black/white marks, the dealership said 1. Ground 2. Computer3. Relay. Which color wire fits each location?
Monday, March 18th, 2019 AT 6:01 PM (Merged)
CARADIODOC
  • 33,754 POSTS
The pink is the power source from the Engine Computer relay. One black wire goes to ground, and the other one is the signal wire that goes back to the Engine Computer. Unfortunately they don't show the connector views like in Chrysler and Ford manuals. Your best bet is to visit a salvage yard and look at the connector on one of their cars. You can even snip it off and splice it to your wiring harness, but don't use butt connectors or Scotch-Lok connectors. Those don't even try to seal out moisture. Solder the splices, then seal them with heat-shrink tubing with hot-melt glue inside. Never use electrical tape. That will unravel into a gooey mess on a hot day.
SRAC
  • 2004 HYUNDAI SONATA
I am having great difficulty in location the following part (even through the dealers). Required location of part of part number
position camshaft CONNECTOR
vehicle details.
004 Hyundai Sonata Gold
Chassis # KMHEN41BR4A927775
Engine # G4JP3904846
CC: 2000
Right Hand Drive
CARADIODOC
  • 33,754 POSTS
I can't even find a listing. How about splicing one in from a salvage yard? What's wrong with yours? Some auto parts stores sell replacement terminals. I use terminals from other sensor connectors and just solder them to the wires to make repairs.
WARFARE21
  • 6 CYL
  • MANUAL
  • 35,000 MILES
Where is the camshaft sensor located and what are the steps in replaceing one
BLUELIGHTNIN6
  • 16,542 POSTS
The camshaft position sensor is located on the engine near the timing belt cover and under the upper radiator hose.
Disconnect the negative battery cable.
Disconnect the connector from the sensor.
Remove the bolt that retains the sensor.
Remove the sensor.
Installation is the reverse of the removal procedure.
Thanks for using 2CarPros. Com!
DYDCC
  • 6 CYL
  • MANUAL
  • 61,000 MILES
Ware is it located on my car, can it be easily replaced
ZACKMAN
  • 4,202 POSTS
https://www.2carpros.com/forum/automotive_pictures/55316_04sonatacmps_1.jpg
https://www.2carpros.com/forum/automotive_pictures/55316_04sonatacmps2_1.jpg
Just one bolt and a wire harness
RODGER80
  • 2002 HYUNDAI SONATA
  • 4 CYL
  • FWD
  • MANUAL
  • 142,000 MILES
I have replaced the cam sensor twwice and have tested the wires at the cam sensor top 12v middle5v bottom ground changed computer and terminal ends at wiring harness to computer have also checked to make certain of connections at cam sensor what else could be causing this problem and also now is occasionally throwing a code for the maf sensor voltage low or high
MERLIN2021
  • 17,250 POSTS
Hyundai has a technical bulletin to reprogram the PCM for this problem. A trip to Hyundai for a reprogramming might be what you need, I will email the PDf to you.
KAD75
I'm having the same problem. I had a code for the o2 sensor and the EGR valve. I cleaned out the carbon in the erg valve and made sure the diaphragm was working and replaced the o2 sensor. Then I got 3 codes p0340, [p0340pd(I don't know what this one is] and 102. I'm going the to try and replace the cam sensor tomorrow.
MERLIN2021
  • 17,250 POSTS
You didn't read this?
KAD75
I did. I just was confused because I had called Hyundai's service department to set up and appointment after reading the replies and explained what was going on to my car and the told me they did they didn't reprogram that. So I give it another shot and I'll ask to speak with one of the mechanic's instead of the appointment desk this time. Thanks for the help
DOREEN C
  • 165,000 MILES
I was driving along and the engine light came on and the car shut off right away. Was analysed and said it was the crank sensor. Replaced that and the timing belt as well. Still no fire. Can the cam sensor be gone as well?
What is the exact code that popped-up?
DOREEN C
P0335
DOREEN C
The code was p0335
