2005 Hyundai Elantra Heater problems
COCOABEAN2010
  • 2005 HYUNDAI ELANTRA
  • 4 CYL
  • FWD
  • 75,000 MILES
My heater is taking longer to get warm even though engine temp gage indicates that the engine is at the normal temp. When it finally gets warm, the heater air gets cold again when idling (at a stop light, etc.)
Thank you!
Do you
have the same problem?
Friday, October 29th, 2010 AT 11:33 AM
WRENCHTECH
  • EXPERT
With the engine at full operating temp, locate the 2 heater hoses where they go into the firewall and feel them to see if they are both hot to the touch. If they are.
The temperature is controlled by the use of an air mix door that is operated by an electric motor/actuator. This door can be jammed or the actuator can be inoperative or have stripped plastic gears internally.
Friday, October 29th, 2010 AT 12:08 PM
Recommended Guides
