2001 Hyundai Accent Installed Junkyard trans Eng turns no e
2001 HYUNDAI ACCENT
150,000 MILES • 4 CYL • FWD • AUTOMATIC
BRENGINEERING
Installed Junkyard trans Eng turns no engaging. It looked like the car was crashed in the side (do not look like the car was junked for a bad trans) and the junk car had 110000 so I pulled the trans. Turn the key the first time and got a little movement from the my car but none since then. I put the eng together with the trans with a little help from the bell housing bolts and rotated the torque converter until the drive lineduo. Bolted the first bolted and rotated the torque converter 3 more times for the other bolts. No DTC and the axles will not rotate and they installed correctly. Comments?
No job 2 years but will donate asap
Mar 20, 2010 at 7:43 PM
