The blower motor?
TIFFANY PARRISH
  • 2008 NISSAN QUEST
  • 122,000 MILES
The blower motor is making a noise like something may be in the motor. Last year mice made a big nest in there and caused $2,000.00 in damage. Wouldn't you know, as soon as the weather turned cool again and the father next door cut down his corn field, it is starting again.
I need to get to the blower motor and clean. How do I get to it?
Friday, September 30th, 2016 AT 10:11 AM
HMAC300
  • 48,601 POSTS
You will have to pull the blower motor out and see if something is in there once again. You are supposed to pull the dash, but see pictures for a short cut. I cannot find the figure 10 he is talking about but I am sure you can figure it out.
Friday, September 30th, 2016 AT 12:34 PM
MASIKUS54
  • 2006 NISSAN QUEST
  • 145,000 MILES
In the morning when I start the car, small knock of the motor fan begins, after a while passes. I think is
motor blower (fan)
I think that I will be able to repair it, but I don't know where precisely to be
Prompt as to it to reach.
Thanks in advance
Tuesday, May 19th, 2020 AT 12:41 PM (Merged)
HMAC300
  • 48,601 POSTS
There are two one at the rightfront and the other at left front. Normally by the radiator either front or back depending on what type they are. You have to find out which one is making the noise first.
TNFAN9
  • 2005 NISSAN QUEST
Heater problem
2005 Nissan Quest Front Wheel Drive Automatic
Got in to start my Nissan Quest, the controls to the blower was in the off position but the blower was blowing out air like it was on high, and then started hearing a clicking noise similiar to the sound when you try to start a vehicle with a weak battery. The only way we could get the clicking noise to stop was to disconnect the battery. Do you have any ideas? Thanks
BLUELIGHTNIN6
  • 16,542 POSTS
The clicking may have been from a bad relay. Check the blower motor relay. If its stuck open then the a/c will be stuck in high positon.
JAINSHAILESH
  • 2005 NISSAN QUEST
  • 3.4L
  • V6
  • 147,000 MILES
How to open the rear RH panel to access the blower motor
  • 31,938 POSTS
I need some more info on model trim level or the cars VIN (Vehicle identification Number)
JAINSHAILESH
5N1BV28U95N105817
  • 31,938 POSTS
This is all I can find, it shows the trim and the attach points, I hope this is what you are looking for.
170WEST
  • 2002 NISSAN QUEST
Heater problem
2002 Nissan Quest 6 cyl Two Wheel Drive Automatic
where is my front blower relay located? How do I access it?
ZACKMAN
  • 4,202 POSTS
https://www.2carpros.com/forum/automotive_pictures/55316_02questfuse_1.jpg
Fuse Block
