Engine Performance problem
2000 Honda Civic 4 cyl Front Wheel Drive Automatic
after engine gets warm it stalls when you push the gas pedal. Fether the gas and takes off fine and goes down road fine under normal acceration.
Friday, April 2nd, 2010 AT 4:57 AM
F4I_GUY
MECHANIC
Scan the vehicle computer for any stored DTC's. If the only code(s) you find are mis-fire codes, I would test the ignition coil and fuel pressure when the vehicle is acting up.
