Power window regulator replacement
PLAYBASS1971
  • 1999 HONDA CIVIC
  • 165,000 MILES
I have a 99 Honda civic lx and the driver side power window mechanism broke. All other power windows worked until I pulled the panel off the driver door to find problem. After finding the the cable broken on motor I put panel back on
Friday, May 11th, 2012 AT 6:06 PM
FIXITMR
  • 9,990 POSTS
The door glass regulator is faulty and is a non serviceable part, needs to be replaced as an assy.
https://www.2carpros.com/forum/automotive_pictures/192750_Civic99DoorRegulator01_1.jpg
Here is a video of the job being done on a similar car.
https://youtu.be/Wp7Ak9IGs4o
Friday, May 11th, 2012 AT 7:07 PM
PLAYBASS1971
  • 5 POSTS
I need to figure out how to get all the windows to work again. I replaced the motor and regulator for driver window and none of the windows work at all. Seems as if no power is getting to any of them. Could it be the master control switch on driver door or is there another relay or fuse I didnt mention in first question. Everything worked fine until the cables broke on driver side window. Then only the theree passenger windows worked. After removing door panel to find problem and replacing door panel the other three windows failed to work. No wires were broken and no plugs unplugged. I have no clue why they dont work now.
Friday, May 11th, 2012 AT 7:18 PM
RICEGRINDER
  • 1999 HONDA CIVIC
  • 4 CYL
  • MANUAL
  • 90,000 MILES
THe driver side power window sticks and drags barely moves. I live near the ocean, Salty, is there any thing to lube the window tracks with to make it slide better or is it time to replace the window motor regulator? If so it there a specialty tool for removing honda door panels?I know that with some windows the alignment is a big deal can that be the cause of improper operationthe manual from haynes is no help any help would be great thanks
Monday, January 4th, 2021 AT 1:42 PM (Merged)
KHLOW2008
  • 41,815 POSTS
Hi ricegrinder,
You can try using silicone spray to lubricate the runchannels.
Normally it is the runchannels that are the cause of the problem. This vehicle comes with minimal adjustment required for replacement of motor.
Monday, January 4th, 2021 AT 1:43 PM (Merged)
WEN2
  • 1998 HONDA CIVIC
  • 15,000 MILES
Glass not alinging
SATURNTECH9
  • 30,870 POSTS
Hope this helps.
KHLOW2008
  • 41,815 POSTS
If the glass keeps going out of alignment while moving up, check the run channels. Try some silicone based lubricants.
2CP-ARCHIVES
  • 4,542 POSTS
  • 1997 HONDA CIVIC
  • 100,000 MILES
Q1) What is a difference between a power window regulator & motor.
My window slides up like a turtle speed.
Q2) My front windsheild glass seems hazy at night. Does it mean its life is over?
CARADIODOC
  • 33,743 POSTS
The regulator is the assembly that allows you to raise and lower the glass. The motor is part of that assembly. When the glass is sluggish, the motor, switch, and wiring are okay. The rubber channels the glass slides in can become sticky. Spray them liberally with Silicone Spray Lube. It goes on like water, evaporates, and leaves a film of "slippery" behind. Works real well for sliding tight radiator and heater hoses onto metal pipes too. You can find it at auto parts stores and hardware stores. Chrysler dealers have it in the parts departments too and I'm sure you would find it at other dealers.
As for the hazy windshield, does it have moisture you can wipe off? If so, the air conditioning is supposed to run in the defrost mode to condense the humidity from the air and dry it before it blows it onto the windshield.
TEARDROP609
  • 1996 HONDA CIVIC
Interior problem
1996 Honda Civic 4 cyl Manual 160000 miles
My window has been coming off the track frequently recently. I know I am in need of a new winow regulator, but when I get my replacement do I need to get the kit that includes the motor or just the regulator itself?
KHLOW2008
  • 41,815 POSTS
Hi teardrop609,
If the glass can open and close completely, use a garden hose to spray some water into the door along the run channels and test, if windows work well, replace the run channel, it should solve the problem.
You can try some rubber rejunevating fluids or silicone/wax spray. NEVER use oil based sprays such as WD40 etc, will cause more problem.
