1991 Honda Civic A 2nd alternator dedicated for HHo product
1991 HONDA CIVIC
247,000 MILES • 4 CYL • 2WD • MANUAL
ESOTERICANDME
I need some help.
I wanna add a 2nd alternator and 2 extra batteries, but have them be on their own separate circuit.
The concept being, have the cars original system running 12v, while having a separate system, power source, and batteries in series at 24v to run my HHO electrolyser.
I'm a backyard mechanic that has no problem welding up a new alt bracket and cutting into my hood if needed, but have no idea about wiring this up.
Jun 2, 2008 at 4:46 AM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
Hi esotericandme,
Hooking up the system is not difficult but will the 2 systems clash I do not know because you are running a 12v and 24 v circuit in parallel unless you can isolate the 2nd alternator grounding separately.
1. 24 v battery positive to alternator main output/input point.
2. 24 v battery current to charge indicator light to alternator charging point, if you want an indicator.
3. 24 v battery current to field coils, you can tap original ignition current supply to operate a relay to act as "ON/OFF" switch.
All done. Don't forget you need to have an alternator with built-in IC.
Jun 2, 2008 at 10:50 AM
