Serpentine belt diagram
ANONYMOUS
  • 2005 HONDA ACCORD
  • 112,000 MILES
Please can you send me a diagram of route of serpentine belt
Saturday, December 15th, 2012 AT 3:12 PM
FREEMBA
  • 1,152 POSTS
Here is a guide that will walk you through the replacement and instructions below to show you how on your car on both 4 and 6 cylinder engines.
https://www.2carpros.com/articles/replace-serpentine-belt
Saturday, December 15th, 2012 AT 3:49 PM
DTLJZARING
  • 2003 HONDA ACCORD
Diagram for install of accessory serpentine belt?
Wednesday, November 13th, 2019 AT 7:19 PM (Merged)
IMPALASS
  • 3,112 POSTS
Hello
https://www.2carpros.com/forum/automotive_pictures/248015_1_25.jpg
JMARTO44
  • 2003 HONDA ACCORD
  • 4 CYL
  • FWD
  • 124,000 MILES
I have a 2003 Honda accord with 124000 miles, 4 cyl, is the drive belt (not timing belt) an item that has to be replaced at regular intervals or do you just inspect it? Is it easy to replace? What are you looking for to inspect it. The manual shows a picture of a pointer but it's very hard to tell what to look for. Thank-you
KHLOW2008
  • 41,814 POSTS
Hi Jmarto44,
No, external drive belts are only replaced as and when necessary but then they would start emitting squeeking noise after a certain period of use. Things to check for are deterioration of the quality of the belt rubber ( cracks, tears, etc)
Replacement is not difficult but proper adjustment is important for durability and won't cause premature wear to driven components.
FUBAR420
  • 2003 HONDA ACCORD
  • 4 CYL
  • FWD
  • 70,000 MILES
Hello, we have a 2003 honda accord lx, 4 cylinder, 2.4 liter, 4 door. The problem we're having is trying to put the serpentine belt back on, so i'm looking for a blueprint or skematics or whatever u wanna call it for the serpentine belt so we can put it back on, if somebody can throw up a picture/diagram for me, or link me to a picture of how the serpentine belt gets put on I would greatly appreciate it, the sooner the better
KHLOW2008
  • 41,814 POSTS
Hi fubar420,
Here we go.
DRIVE BELT REPLACEMENT
Special Tools Required
1. Belt tension release tool Snap-on YA9317 or equivalent, commercially available. Move the auto-tensioner (A) with the belt tension release tool to relieve tension from the drive belt (B), and remove the drive belt.
https://www.2carpros.com/forum/automotive_pictures/192750_DriveBelt03Accord4CylFig14_1.jpg
2. Install the new belt in the reverse order of removal.
https://www.2carpros.com/forum/automotive_pictures/192750_DriveBelt03Accord4CylFig01_1.jpg
FURNACEMANJOE
  • 2004 HONDA ACCORD
  • 4 CYL
  • 850,000 MILES
How do I replace the serpentine belt on a 2004 honda accord 4 cyl engine
Wednesday, November 13th, 2019 AT 7:20 PM (Merged)
KHLOW2008
  • 41,814 POSTS
1. Move the auto-tensioner (A) with the belt tension release tool to relieve tension from the drive belt (B), and remove the drive belt.
JEANIE3383
  • 2000 HONDA ACCORD
2000 Honda Accord 6 cyl 170000 miles
How much does it cost to replace a serpintine belt and a belt tentioner? And what does it mean when your car won't always turn over or start up but all the lights stay on and the radio it only happens every so often?
Wednesday, November 13th, 2019 AT 7:23 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi jeanie3383,
If the starter is not cranking with the dash lights staying on, it could be a faulty starter motor, security system or faulty ignition switch. Check if starter solenoid wire is secure. Is the security light ( green key symbol ) blinking at this time?
The labor time for replacing the drive belt tensioner is 0.7 hour.
$ 19.88 = Serpentine Belt
The price for drive belt tensioner is not available in our database.
VICKIROSE00
  • 2002 HONDA ACCORD
  • 2.4L
  • 4 CYL
  • FWD
  • 200,000 MILES
Was driving to ruston louisiana from baton Rouge which is a 3 hour drive. About an hour in I heard a pop and the battery light the break light and all the door lights came on. Kept driving for about an hour and then my dashboard went out so I pulled over and got a tow all the way back to my house. The bride belt wasn't there when I looked under the hood and the power steering belt was still attached. The car also started up after I turned it off when I tried to start it. My question is ifor the dashboard only went out because the belt wasn't on. Or did I completly screw up my battery and engine. P.S. I replaced the battery and alternator about 2 months ago
Wednesday, November 13th, 2019 AT 7:24 PM (Merged)
HMAC300
  • 48,601 POSTS
Best thing here Is to replace the belt and tensioner as recommended at 60000 miles. Then start it up and see what you have.
TITO9632
Hi I have a Honda 2012 and I try to back Serpentine Diagram, Can you please help me?
Tuesday, November 22nd, 2022 AT 1:29 PM
  • 108,355 POSTS
We would be happy to help. However, I have a favor to ask. I need you to start a new post with your model year, make, model, and engine size so we can get the right information for you.
We ask that you start a new post because of the difference in model years from the original post. We try to keep it specific to one type of vehicle so that it is helpful to others. I hope you understand.
Here is the link to start a new post. Copy and paste your question and someone will help. Please make sure to include the engine size.
Again, I hope you understand.
Saturday, November 26th, 2022 AT 7:52 PM
