2002 Honda Accord shift solenoid A electrical
TRASHDADDY
  • 2002 HONDA ACCORD
  • 4 CYL
  • FWD
  • 110,000 MILES
Will replacing the part fix the problem diagnostic code 0753 drive 4 is flashing and what is the part number for the part
Do you
have the same problem?
Tuesday, May 11th, 2010 AT 6:09 PM
KHLOW2008
  • EXPERT
DTC P0730/41: SHIFT CONTROL SYSTEM
NOTE:
Do not perform this DTC test until all other DTCs have been repaired first.
1. Using scan tool, retrieve freeze data. Clear DTCs and road test vehicle under same conditions freeze data was recorded. If DTC returns, go to next step. If DTC does not return, problem is intermittent. Check transaxle and PCM connections.
2. Road test vehicle at greater than 12 MPH for more than 30 seconds in 2nd, 3rd and 4th gear. Using scan tool, check for any other DTCs. If any other DTCs are present, repair those DTCs first, and then recheck for DTC P0730/41. If no other DTCs are present, go to next step.
3. Test clutch pressure. If clutch pressure is within specification, go to next step. If clutch pressure is not within specification, repair hydraulic system as necessary.
4. Replace lock-up control solenoid valve/shift control solenoid valve "A" assembly and shift control solenoid valves "B" and "C". Turn ignition off and clear DTCs. Road test vehicle at greater than 12 MPH for more than 30 seconds in 2nd, 3rd and 4th gear. Recheck DTCs. If DTC P0730/41 returns, replace transaxle. If DTC P0730/41 does not return, system is okay.
Thursday, May 13th, 2010 AT 2:22 PM
Recommended Guides
