does anyone know what would cause a transmission to not want to shift from first to second gear on cold days when temp is below 40 degrees. There is also a slight jerking effect when putting the transmission into to drive. This issue does not happen if we let the run for a couple of minutes. Seems strange. Never saw this problem until shortly after having transmission axel seals replaced.
Friday, January 4th, 2008 AT 11:07 AM
