1997 Honda Accord Frequent failure of steering pump and ign
1997 HONDA ACCORD
166,000 MILES • 4 CYL • FWD • AUTOMATIC
OTOBONGI
I have change my steering pump about 3 times in the last 6 months due to failure. The pump becomes hard and difficult to steered the wheel.
Also, I have frequent ignition off of the engine while driving. I have change the fuel pump, fuel filter and clean the fuel tank yet the engine goes off whenever I apply brakes occasionally and the firing is poor. Please assist
Aug 5, 2010 at 7:13 AM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
Hi otobongi,
When the P/S pump was replaced, did it solve the problem then?
Did you check if it is a fault of the pump ?
What is the condition of the P/S fluids? Clean or dark?
Did you clean the reservoir?
Were the replacement pumps new, used or rebuilt?
Does the engine stall only at a stop? If yes, then it is a fault of the idling system, the fuel system has nothing to do with it.
What it the idling speed at operating temperature?
Does the idling speed drop when the A//C is turned on?
You mentioned the engine is running badly, were the spark plugs and related parts checked?
Aug 7, 2010 at 11:09 AM
