1996 Ford Thunderbird unidentified knocking noise
CATAKLYSTIA
  • 1996 FORD THUNDERBIRD
Noises problem
1996 Ford Thunderbird 6 cyl Two Wheel Drive Automatic
I have a 96 Thunderbird and it makes knocking noise when I push the excellerator, but stops when I hit the emergency brake (I had it up on blocks for this). It sounds like a little like a CV joint going out, only it doesn't have one, or a U-Joint, but that looks fine too. It doesn't change from second to third gear either. What could the issue be?
Do you
have the same problem?
Sunday, March 28th, 2010 AT 4:36 PM
  • EXPERT
Does it change with the speed of the car?
Friday, May 14th, 2010 AT 1:35 PM
Recommended Guides
