Bad starter?
ERICA BOYCE
  • 2012 FORD TAURUS
  • 100,000 MILES
I had to jump my battery right after I parked it. It was good than for about an hour and than it wouldn't start again. When I would try to start the car, the lights would start flashing. I replaced the battery but I am starting to think its the starter. Maybe?
Friday, July 8th, 2016 AT 8:35 PM
CJ MEDEVAC
  • 11,004 POSTS
Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
Friday, July 8th, 2016 AT 8:58 PM
JOHNNY G.JR
  • 320 POSTS
Have battery charged fully then have it load tested at parts store, possible that alternator is not up to snuff
Friday, July 8th, 2016 AT 9:39 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,057 POSTS
Hi ERICA,
It sounds like you may have a battery that is weak or an alternator that needs testing here are some guides that will help you.
and
https://www.2carpros.com/articles/how-to-check-a-car-battery
Friday, July 15th, 2016 AT 9:24 AM
LHEVRON81
  • 2006 FORD TAURUS
  • 3.0L
  • 6 CYL
  • FWD
  • 108,000 MILES
Hi, I'm replacing the starter in my car, and have removed all the wires, and both bolts. The starter still won't budge.
Sunday, April 26th, 2020 AT 12:42 PM (Merged)
HMAC300
  • 48,601 POSTS
If all the bolts are out holding it in from back (3) then tap with a rubber hammer or block of wood to break it free
BOSSONE
  • 2005 FORD TAURUS
Engine Mechanical problem
2005 Ford Taurus Front Wheel Drive Automatic 1300 miles
how much is it to replace starter on a 2005 ford taurus
DAVE H
  • 13,383 POSTS
OEM dealer part starter motor
OHC $166
OHV $179
1 hours labor @ shop hourly rate (usually around $70 p/h)
you could probably get the parts cheaper at an autoparts store?
Hope this helps. Merry xmas
WOLVEANGEL
  • 2004 FORD TAURUS
  • 6 CYL
  • FWD
  • 145,000 MILES
How to replace the starter in my car
Sunday, April 26th, 2020 AT 12:43 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
Disconnect negative battery cable.
Raise and support vehicle.
Remove splash shield.
Disconnect wiring from starter solenoid (and starter motor ground strap on 3.0L engines).
Remove upper and lower starter bolts.
Remove starter.
To install, reverse removal procedure. Tighten bolts to specification
RICK FREY
  • 2003 FORD TAURUS
  • 4 CYL
  • FWD
  • 128,000 MILES
How long should it take for a Ford dealers service department to replace a starter motor? I was charged $300.00 or almost 3 hours of work.
Thanks
CARADIODOC
  • 33,754 POSTS
That sounds about right. I used to provide my students with a page of business taxes, government regulations that we voted for, insurances, and all the other expenses including all the freebies they give away. After looking at that double column, tiny font, full-page list, it is really hard to figure out how they can manage to stay in business when charging only $100.00 per hour. Other businesses face the same handicaps placed on them by various government agencies, but not nearly to the extent the automotive industry has to deal with. You and I pay for it in the long run.
I can still remember, when working at a very nice family-owned Chrysler dealership in the '90s, we were charging just under $60.00 per hour, and we were amazed to hear the local Goodyear store was charging $75.00 per hour. They were the highest in the city. Today most shops are charging around $100.00 to $110.0 per hour, but that varies a lot in different parts of the country.
SCRAMMAN
  • 2003 FORD TAURUS
  • 6 CYL
  • 50,000 MILES
The first time I had this problem, the car became increasingly harder to start. Eventually was able to jumpstart it, but that eventually failed. Removed the start and it was burned up. Replaced the starter and the battery. Three months later, same thing happened. Can't jumpstart the car. I am getting ready to replace the starte and I am pretty sure it will be burned up. What's going on?
PEAR69
  • 1,482 POSTS
What is the voltage of the battery measured at the terminals with a high impedence volt meter (not the dashboard reading)- with and without the engine running?
SCRAMMAN
Car is not located at my location. Will check.
Thanks for your response.
LRENZ
  • 2003 FORD TAURUS
  • 6 CYL
  • 36,000 MILES
How do you replace a starter on a 2003 Taurus?
LEGITIMATE007
  • 5,121 POSTS
https://www.2carpros.com/forum/automotive_pictures/88091_ScreenHunter_01_Sep_04_2316_1.jpg
FOREST11
  • 2002 FORD TAURUS
  • 6 CYL
  • FWD
  • 140 MILES
How to replace the starter?
  • 108,310 POSTS
Disconnect the battery, remove the wiring from the starter, unbolt the starter from the engine and remove it. Reverse the order to replace.
EMCDONALD
  • 2002 FORD TAURUS
  • 6 CYL
  • 128,000 MILES
I have to replace a starter on the above car. It is confirmed the starter is dead.
Please advise of the steps necessary to replace the starter
MATHIASO
  • 1,209 POSTS
To be precise in helping you tell me wich one is your ford taurus?
6 Cylinders 2 3.0L Flex Fuel OHV (found in 16% of 2002 Ford Taurus)
6 Cylinders S 3.0L EFI DOHC (found in 19% of 2002 Ford Taurus)
6 Cylinders U 3.0L EFI (found in 65% of 2002 Ford Taurus)
