2001 Ford Taurus Coolant Temperature Sensor
SHARKWATER
  • 2001 FORD TAURUS
  • 6 CYL
  • 14,000 MILES
My dashboard gauge reads "cold", even after the engine has warmed. I've replaced the thermostat, but now. Any suggestions to proceed?
Monday, June 7th, 2010 AT 1:11 PM
BADWUFF
  • 13 POSTS
Sounds like either your temp sensor on your engine or your dash unit may be defective. Or wiring.
Monday, June 14th, 2010 AT 11:41 PM
BMRFIXIT
  • 19,053 POSTS
Do you have check engine light on?
And if so have to scan for codes
if no check engine use a scanner tool select data and check what it say for engine temp
An out-of-calibration sensor may not set a trouble code, but it will cause driveability problems.
Tuesday, June 15th, 2010 AT 5:51 AM
Related General Content
