Headlights not working
CURTISCASWELL
  • 2004 FORD TAURUS
Headlights won't work have changed bulbs/headlight switch what else should I try?
Friday, September 21st, 2012 AT 9:27 PM
KHLOW2008
  • 41,814 POSTS
There is an auto headlamp relay that needs to be checked here is a guide to help you test it with the relay location as well as the headlight wiring diagrams so you can see how the system works.
Friday, September 21st, 2012 AT 10:27 PM
ZANYJB
It was the relay, thanks for this post I have to say I just love this website.
Monday, February 4th, 2019 AT 3:07 PM
MCFIXIT
  • 2001 FORD TAURUS
My girlfriend recently got into an accident in her 2001 Ford Taurus. The passenger side headlight got smashed and does not work, however the driver side headlight stopped working also. There is no damage on that side of the car, and both sides daytime lights and highbeams continue to function.
Just looking for some insight as to why the other side would stop working.
Checked all the fuses and none appear to be blown, but that's about the extent of my knowledge of car repairs.
Any help would be greatly appreciated.
Thanks
Monday, February 4th, 2019 AT 3:08 PM (Merged)
WRENCHTECH
  • 20,758 POSTS
Have you tried a new bulb yet?
BMRFIXIT
  • 19,053 POSTS
Damaged light bulb on one side may cause a fuse damage
disconnect the damaged bulb and check wiring not touching metal
recheck fuses in central junction box under left side of dash
and if all checks OK check bulb it self as it may be bad too
BREAKER1954
  • 2000 FORD TAURUS
  • 6 CYL
  • FWD
  • 120,000 MILES
The Auto headlamp electrical system quit working working. Where do I start looking?
BMRFIXIT
  • 19,053 POSTS
Check fuses 1st and relays
check make sure headlights ok
check switch wiring and switch
